revs sticking... done checks, still the same?
i have some problems on a d16z6 basically i have the common rev's sticking problem, when i come to pull up at a junction the revs hang at about 2k and then drop down to right level and the choke doenst kick in on a cold start up aswell
cleaned the IACV, screwed the white plastic thing in the FITV and checked the PCV valve, and dont seem to have a vacum leak
any ideas what else it could be?
Re: revs sticking... done checks, still the same? (60019184)
did you remove the intake manifold or mess with the throttle body at all? i had this problem when i installed a new IM but it was the throttle cable, not enough slack between TB and the pedal.
wes7side5o
15
03-16-2007 06:47 AM
bumthology
01-13-2006 09:06 AM
