replacing distributor cap and rotor, will timing change?
Old 05-13-2005, 09:09 PM
ice11honda's Avatar
Default replacing distributor cap and rotor, will timing change?
I just changed my wires, dizzy cap and rotor. I made sure the new rotor went back on in the same place old rotor was at. Will my timing remain the same or will it have changed? Thx
Old 05-13-2005, 09:25 PM
cruizinmax's Avatar
Stays the same. I would probably check it anyways if you are doing a tune up.
Old 05-13-2005, 09:37 PM
nocturnaldragon's Avatar
Default Re: replacing distributor cap and rotor, will timing change? (ice11honda)
I belive you can only put it back on one way. Either case ive never heard of it changing by doing such.
Old 05-13-2005, 10:49 PM
Unceasing Measure
Archidictus's Avatar
Default Re: replacing distributor cap and rotor, will timing change? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">I belive you can only put it back on one way.</TD></TR></TABLE>
Truth.
Old 05-13-2005, 10:53 PM
Andres-eh2's Avatar
to be on the safe side, i always draw a mark on top of the dizzy that crosses to the other side as a reference
Old 05-14-2005, 05:45 AM
ice11honda's Avatar
Default Re: (Andres-eh2)
Awesome!! Thankyou all for the help. I an not so confudent some times and it is good to have othrs reassurance. Thx again.
Old 05-14-2005, 05:47 AM
HATCHingMN's Avatar
Default Re: (ice11honda)
it will stay the same ....unless you turn the whole distributor LEFT or RIGHT
Izo
05-22-2011 07:54 PM
B18C5er
11-15-2004 05:20 PM
Xxcivic99xX
10-24-2004 01:07 PM
uNF$@#!
03-28-2004 11:48 PM
Quick Reply: replacing distributor cap and rotor, will timing change?
