Removing center console on 99-00 Civic?
Old 08-12-2002, 09:09 AM
Gump's Avatar
Default Removing center console on 99-00 Civic?
Anybody know how to remove the center console on a 99-00 Civic? I need to pull out the radio so that I can get the serial number for the radio, I lost the code.
Old 08-12-2002, 09:15 AM
Spade's Avatar
Default Re: Removing center console on 99-00 Civic? (Gump)
Screws underneath.....look up from laying down on the passenger side floor.
Old 08-12-2002, 09:27 AM
Gump's Avatar
Default Re: Removing center console on 99-00 Civic? (Spade)
pulled those out, is there anything else? I was trying to pry it off, but it seems a little on the weak side, and I don't want to break it.
Old 08-12-2002, 09:32 AM
Spade's Avatar
So you removed the panel and then removed the screws that hold the console in place?
After that you must disconnect all the electrical connections inside.....some are short and must be disconnected before fully pulling out the console.
Old 08-12-2002, 09:35 AM
Gump's Avatar
I unsrewed it first, but I was trying to pull it off, and it seem like it was still being held by something other than screws and metal tabs that it pops into, is there anything else holding it like other hidden screws?
Old 08-12-2002, 09:37 AM
Spade's Avatar
Nope. Just the connections.....pull the antanne out of the back of the radio....that will sometimes full you as if you havn't disconnected everything.
Old 08-12-2002, 09:42 AM
Gump's Avatar
Thanks man! I'm going to try it again.
Old 08-12-2002, 09:45 AM
New User
lliew's Avatar
Try this site too. It helped me pull my dash apart to wire in my amp and sub.
http://www.installdr.com
Old 08-12-2002, 11:45 AM
BagelW's Avatar
You are talking about the panel underneath the AC and defroster buttons that has the power outlet on it, right?
There are bolts that hold that piece on that you can only get too by taking off the panel under the steering wheel and taking out the glove box. Once you've done that, you'll be able to take that panel completely off.
Old 08-12-2002, 12:15 PM
Gump's Avatar
Default Re: Removing center console on 99-00 Civic? (Bagel Williams)
Just finished, thanks for everyones help.
prada_G
04-19-2008 09:05 PM
Nickvw
07-04-2007 06:15 AM
Heylookits shawn
Northern California (Sales)
01-03-2006 09:57 PM
FBP EM1
09-27-2005 09:20 PM
ferio 95
10-25-2004 03:36 PM
Quick Reply: Removing center console on 99-00 Civic?
