Refresh of 94 Civic Si w/ ABS after accident
#151
Seagull Management
Re: Refresh of 94 Civic Si w/ ABS after accident
If I have a OBD2 GSR swap (engine is from a '96) going into my OBD1 body ('94 EH3), what is the guidance?
I do want to keep the evap purge function, the car smells awful when purge is not purging.
So if I want to keep using A17, switched (-), where is this dead end plug YEL/BLK? It provides (+) from the PGM-FI main relay, yes?
Thank you again for your time.
The dead end plug is an 8 pin connector, all wires are yellow/black, you can't miss it. Yes it's switched 12v ignition power.
#152
Premium Member
If you're using an OBD1 ECU (which I assume you are) use the wiring diagram for an OBD1 setup. I know the part number for the solenoid changes from OBD1 to OBD2 but I don't think it matters.
The dead end plug is driver side, near firewall, in the engine compartment? I will look for that as 12v (+) supply.
Then I will need to figure out which IAB solenoid I have, as there are 2 different P/Ns:
'94-'95 Valve Assembly, Bypass Control Solenoid 36163-PT2-004 - http://www.hondaacuraonline.com/acur...ntrol-solenoid
'96-'01 Valve Assembly, Bypass Control Solenoid 36163-P72-003 - http://www.hondaacuraonline.com/acur...ntrol-solenoid
I don't know if these solenoids are sensitive to polarity? It looks like the connectors switched polarity when going from OBD1 to OBD2. First image is OBD1 (uses YEL/BLK +), second image is for OBD2 (uses BLK -):
#153
Premium Member
I found some automotive wire available in PNK/BLU and YEL/BLK. I think I can get this cleaned up alright: 16 gauge GXL: 16 Gauge GXL Wire HARLEY AUTOMOTIVE WIRE STRIPE WIRE 300 COLOR AVAILABLE ANY LENGTH
#154
Premium Member
I had hoped to get some work done this weekend, but the highs yesterday were 37 degrees, today it snowed until ~10 AM. The sun is coming out now, so I may do a little work, but for the most part the weekend has been a bust.
I did get some work done on this shifter last weekend, so I can provide updates on that...
#155
Premium Member
Re: Shifter, Part 2
If you want to see all the pieces you can replace on your shift rod in the hopes of getting rid of the rattle - here they are.
As I said above, my B&M short shifter does not use the thrust washers or joint bushings called for. I doubt it will be worth shipping them back to return. I will figure out what o-rings I am supposed to use with the short shifter and get some new ones of those.
The shortened rod does put the shifter in a more neutral position that feels right while sitting still. This less sever angle might also alleviate the rattle I had previously. One can hope...
While I had both rods for the shifter down, I replaced the boot that seals the opening in the floor tunnel as the old one was torn and distorted.
Last thought on the shifter - it is a LOT easier to replace these parts with the shifter assembly out of the vehicle, and the exhaust out of the way!
#156
Premium Member
Looks like it is time to go shopping, can't find these items for rent at local parts store...
Ring compressor: https://www.amazon.com/ARP-901-8100-...ing+compressor
400 grit ball hone: https://www.amazon.com/83mm-Flex-Hon...ne%2C+400+grit
#157
Premium Member
Stumbled across some knowledge about pin-outs for the B18C1 swap into EG: https://honda-tech.com/forums/hybrid...stion-3289117/
This will help me as I plan on cleaning up some poorly-done splices over the weekend...
I have one terminal of IAB hooked up to A17, which should be switched ground (-).
The other terminal is grounded at the thermostat housing.
If I am correct, then my IAB never worked for 14 years.
This may explain why it felt like I never had any low-end torque off idle...
I decided to get a little more OCD about this project and order up some correctly color striped wire. I also found some cool solder-seal/heat-shrink/water-proof connectors. Can't wait to wire!
#158
Premium Member
Here you can see I ordered PNK/BLU, YEL/BLK, and RED/BLU. My cat wanted to photo bomb the shot - you can see his paw in the lower corner as he was running in to lie down on the wire!
#159
Premium Member
I am using an OBD1 P72 ECM, so I will use the A17 switched ground (-).
'94-'95 Valve Assembly, Bypass Control Solenoid 36163-PT2-004 - Acura INTEGRA HATCHBACK VALVE ASSY., BYPASS CONTROL SOLENOID Great Prices on Acura INTEGRA HATCHBACK Parts - Fast Delivery! : Honda Replacement Parts Acura Parts Online Honda Parts And Accessories - HondaAcuraOnline.com
'96-'01 Valve Assembly, Bypass Control Solenoid 36163-P72-003 - Acura INTEGRA HATCHBACK VALVE ASSY., BYPASS CONTROL SOLENOID Great Prices on Acura INTEGRA HATCHBACK Parts - Fast Delivery! : Honda Replacement Parts Acura Parts Online Honda Parts And Accessories - HondaAcuraOnline.com
The sun came out a little bit today, so I thought I would check this out. I agree with @94EG8 that it does not seem to matter which solenoid I have. When I hook the IAB solenoid I have up to 12 volts, it clicks closed - regardless of polarity. So if I hook up my IAB correctly, it should close, blocking manifold vacuum from reaching the vacuum diaphragm at the intake, and therefore giving me the correct length intake runners until engine RPM hits 5,750 RPM and the switched ground (-) turns off, IAB solenoid opens, and manifold vacuum hits the vacuum diaphragm and the shorter runners for higher RPM are used.
#160
Premium Member
I'm glad I got a little time to look at the Civic today. When I was taking things apart I flushed out the heater core with water. Lately the weather has been cold - getting down below freezing at night. At some point I thought about the temps and wondered if I still had water sitting in the heater core. It turns out I did - - So I blew out the water that was in there and poured some alcohol through to melt any ice that may have been in there and displace the water that had been left in there.
I hope the heater core did not get ruptured by ice. I will try to pressure test it when I put the new hoses on.
#163
Here's a picture of a canister I think might work for you:
I'm not sure what car this is out of. The inlet from the tank is SMALLER than the outlet to the purge on this canister. This might be from a 96-00 Civic DX, or possibly from an Integra. Here's a thread where someone details changing their fuel filter on their 96-00 Civic DX, and you can clearly see the orange fresh air tube for the canister clipped to the fuel filter bracket as well as the charcoal canister with a single inlet/outlet on it (fourth image):
https://honda-tech.com/forums/honda-...ilter-2872418/
I suspect that's what this one is from. But this might work for you. In my images, PURGE is on the left, TANK on the right. The canister says "TENNEX" on it.
#164
Premium Member
#165
Crazy! I wonder why there is a second fresh air tube that goes straight up? I wonder the fresh air vent on our charcoal canisters have this design as well? I appreciate you thinking of me. We'll have to get together as I get closer to getting her back on the road. With a forecast high of 1 degree this weekend, I don't think I will get too much work done...
Yeah, too cold for me too! Just let me know, I'll hang on to it.
#166
Premium Member
#167
Premium Member
'94-'95 Valve Assembly, Bypass Control Solenoid 36163-PT2-004 - Acura INTEGRA HATCHBACK VALVE ASSY., BYPASS CONTROL SOLENOID | Great Prices on Acura INTEGRA HATCHBACK Parts - Fast Delivery! : Honda Replacement Parts | Acura Parts Online | Honda Parts And Accessories - HondaAcuraOnline.com
'96-'01 Valve Assembly, Bypass Control Solenoid 36163-P72-003 - Acura INTEGRA HATCHBACK VALVE ASSY., BYPASS CONTROL SOLENOID | Great Prices on Acura INTEGRA HATCHBACK Parts - Fast Delivery! : Honda Replacement Parts | Acura Parts Online | Honda Parts And Accessories - HondaAcuraOnline.com
#169
Fish Twig
Re: Rack!
Rack is in!
Before I installed, I cleaned the PS lines by putting some compressed air through the open lines up by the PS fluid reservoir, then brake-clean, then more air. I did not realize how much fluid was still in there, so I made a nice puddle of PS fluid to lie in while I swapped out the racks - awesome!
This is not too bad with the intake and head out of the way. I sense it would suck to do with the whole engine in there. It definitely helped that I did a dry run last weekend. I think the worst part was biting the bullet and paying - straight cash, homie $$$
1. forgot to push the driver side inner rod in towards the passenger
2. forgot to remove the grommet
the linkage that holds the column to the pinion was still stuck on there but that was no biggie, just the above 2 kept me from removing and twisting the rack. All out now baby!!
with the engine in the car, so yes referring to your other thread it is possible to remove the rack with the subframe on.
#170
Premium Member
Re: Rack!
Just had to pull the rack from my sisters db7, I had to go back to the helms manual for some key things I forgot to do to remove it.
#171
Premium Member
We finally had some nice weather on a weekend for a change, so I got some time to work on the Civic today - awesome!
I don't see a post from when I ran new wires for IAB and Knock, and re-pinned the A and D connectors. I have some pictures I can pull for that.
Today I got to replace 3 of the 4 heater hoses. The 4th hose - the one that connects the heater valve to the head will go in once I get the head on.
#172
talks to himself
Taking advantage of nice weather to work on cars feels great but then it's also kinda shitty because there's so many other things that could have been done. Way to get out and get after it, though.
#174
Premium Member
I think I have been pretty clear about my disappointment in the overall quality of workmanship from the outfit that swapped the B18C1 into my little EH3. Overall, I love the car, and in spite of the shoddy work, things held up fairly well. I did have to spend some coin right after I got it back to un-**** some basic things they should have done. This picture here sums things up I think. You can see multiple splices, generic heater hose, multiple hose clamps. etc:
Some of the splices are close to the connectors as well - see Knock and IAB. when I went looking for the IAB wiring at the ECU, I decided to do something about it and improve the wiring that I did not like.
Here are the wires to ECU A & D for IAB and Knock - why? Just Why?
