which radiator hoses for b16 eg swap
Old 02-13-2006, 07:55 PM
94hatchling's Avatar
Default which radiator hoses for b16 eg swap
i'm having trouble finding the thread where it says which radiator hoses fit properly for a single side radiator, with a b16 swap. the hoses in my car are for something else, and fit, just have to crush the hose where it meets the radiator to get it to seal properly. so i'm guessing i have the stock single core radiator since the inlet/outlet for it are smaller then the hoses. will hoses for a 99-00 civic si fit properly? i'd rather not have to tighen the clamps to the extent of crushing the hose. just want the best seal possible.
my bottom hose is now leaking, and want to replace both hoses with the proper ones when i replace my timing belt, since i will already be under the car and the coolant will already been drained. its something like a bottom hose from an integra and a top hose from a del sol or something. so if someone could inform me of what year, model, and engine i need to get the hoses for i would greatly appreciate it.
Modified by 94hatchling at 5:57 AM 2/14/2006
Old 02-14-2006, 02:57 AM
***morning bump***
Old 02-14-2006, 10:32 AM
bump before class
Old 02-14-2006, 11:20 AM
civicb16eg's Avatar
Default Re: (94hatchling)
del sol dohc vtec (b16a3)
Old 02-14-2006, 12:19 PM
Del Sol SiR's Avatar
Default Re: (civicb16eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicb16eg &raquo;</TD></TR><TR><TD CLASS="quote">del sol dohc vtec (b16a3)</TD></TR></TABLE>
94-97 Del Sol VTEC
Old 02-14-2006, 01:26 PM
Default Re: (Del Sol SiR)
thanks guys... i appreciate it. one of those little things i hadnt learned yet. will pick those up today when i go get my oil, coolant, etc for when i do my timing belt change. thanks again.
Old 02-14-2006, 01:31 PM
xhatchracerx's Avatar
anyone know if this will work for a EK B16 with one sided radiator
Old 02-14-2006, 01:32 PM
* B A N N E D *
J Rob's Avatar
Default Re: (xhatchracerx)
You can also use integra gsr hoses with clamps.
dcraige
06-24-2010 07:43 PM
streetracerof06
02-13-2006 01:14 PM
streetracerof06
11-05-2005 11:21 PM
doublejz
10-12-2003 06:24 PM
Quick Reply: which radiator hoses for b16 eg swap
