problem with timing
Old 11-04-2008, 06:50 AM
jwizzie2001's Avatar
Default problem with timing
the crankshaft pulley gear on my car spun out and rounded out the key way . so me and my friend put a new one on with some jb weild trying to fix it but we bolted up so it would get a good hold on the gear now the bolt i think is jb welded into place is there any way to set the timing for the timing belt without taking the crank pulley off .
Old 11-04-2008, 06:52 AM
EkFG's Avatar
Default Re: problem with timing (jwizzie2001)
yes look at the notches on the pully and line it up to the mark on the lower timing cover
Old 11-04-2008, 06:58 AM
Default Re: problem with timing (EkFG)
we took the timing cover off the only way to get it back on is to cut it and wat mark on the pulley
Old 11-04-2008, 07:16 AM
EkFG's Avatar
lol, oh man then the sprocket that the timing belt rides on has a timing mark align that to the mark on the oil pump..i think the marks on the oil pump it a very noticeable notch.
if your crank pulley is clean you will notice it has 3 lines on the ridge, right by where the alternator rides on. it will have 4 notches three ate close together and on is a but farther use the farther line ( notch)
DavidCRV
08-26-2013 03:12 PM
ThA IntegrA HI
12-17-2009 06:37 PM
Danronian
04-12-2006 03:06 PM
OBD-One-Kanobe
11-01-2002 09:21 AM
Quick Reply: problem with timing
