Oil leak from distributor
I have a small oil leak under my distributor on d16z6 I replaced the distributor seal and the leak got better but every time I degrease it I can still see alittle oil and I can smell it burning after I turn the car off, what else could cause this?
Re: Oil leak from distributor
I've already replaced the o-ring I'll try the distributor seal, but it jut doesn't seem like its leaking out of the distributor, I'll try it and see.
If there's no oil inside the distributor, then the internal distributor seal is fine. In this case, you need to replace the distributor O-ring, the valve cover gasket, or the VTEC solenoid gasket. Post pictures of the oil leak.
Is there ANY oil inside the distributor? Did you install the OEM Honda O-ring?
Post pictures from the other side of the distributor so that we can see the VTEC solenoid and the coolant temp sending unit.
I use silicone gasket seal. It works well. But I couldn't find this gasket anywhere and all auto shops told me to get it from dealer. Make sure to clean the solenoid really well and let it air dry. Also, a lot of oil will come out.
hey guys today i replaced the vtec selenoid seal, the seal looked pretty new, but i put the new in anyways, and ive still got a bit of a leak, it feels like its wet under the black part of my distributor, is there a seal in there that needs to be replaced?
