power steering
Old 05-16-2007, 04:55 PM
FOOLS_Si's Avatar
Default power steering
how much hp will i get and would it be worth it to take off my p/s. i jus took off my a/c yesterday?
Old 05-16-2007, 05:02 PM
egb16pg's Avatar
Default Re: power steering (FOOLS_Si)
ac reduces about 3-7 horses/2-5 miles to the gallon when running. idk about power steering though.
Old 05-16-2007, 05:18 PM
Darth ModerVader
Padawan's Avatar
The dyno results I've seen for a B-series indicate a gain of between 4-7 whp from removing the power steering. D-series results should be reasonably similar. Gains from from removing the A/C would be negligible, since the A/C compressor has a clutch that keeps it from engaging while the system is switched off.
Old 05-16-2007, 05:54 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: power steering (Padawan)
Likely not worth the headache and lack of A/c unless it's a fulltime track car.
But for me, I'd like to have it on my track car. I loathe being hot.
Old 05-16-2007, 05:56 PM
FAILWGN
Micha's Avatar
Default Re: power steering (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOOLS_Si &raquo;</TD></TR><TR><TD CLASS="quote">how much hp will i get and would it be worth it to take off my p/s. i jus took off my a/c yesterday? </TD></TR></TABLE>
Why would you take off your AC? I woulda kept that if anything. I had a EJ2 with no AC last summer and it sucked.
Old 05-16-2007, 06:02 PM
FOOLS_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Gains from from removing the A/C would be negligible, since the A/C compressor has a clutch that keeps it from engaging while the system is switched off. </TD></TR></TABLE>
idk about it being negligible cause i felt a little umph under the pedal. explain more in depth into the last line you had. i took off the whole compressor, a/c radiator, fan, all lines, and belt. i thought i got some hp.
is there anything special that i need to do in order to remove my p/s?
Old 05-16-2007, 06:03 PM
FAILWGN
Micha's Avatar
You will need a manual steering rack or you have to loop the steering hose back onto itself.
Old 05-16-2007, 06:07 PM
Darth ModerVader
Padawan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOOLS_Si &raquo;</TD></TR><TR><TD CLASS="quote">idk about it being negligible cause i felt a little umph under the pedal. explain more in depth into the last line you had. i took off the whole compressor, a/c radiator, fan, all lines, and belt. i thought i got some hp.
is there anything special that i need to do in order to remove my p/s?</TD></TR></TABLE>
The A/C compressor essentially spins freely when the A/C is switched off. Therefore, there is basically no extra drag on the engine, and no real power gains from removing the system.
When removing the PS, many people chose to use some form of loop setup connected to the open fittings that are left on the rack.
Old 05-16-2007, 06:40 PM
yeegsr's Avatar
OMG YOU TOOK OFF YOUR A/C FOR HP. Give me your A/C man.
haha...DON'T DO IT....I'm trying to put my PS back on man. I have been driving without it for yrs and it gets a little old and not worth it.
Taking PS off DOES NOT GIVE HORSE-POWER YOU HP-HUNGER...yes, it does free up the power of your drivedrain of the crankpulley for a little better rev. But you can't even tell for ****.
See my aviator? don't be NOOB
Old 05-16-2007, 06:42 PM
Ek Forever y0!
Default Re: power steering (yeegsr)
It's definately not going to give you 1/10th of a second off of your 1/4.
Even if it did i would still rather be 1/10th of a second slower and comfortable.
Old 05-16-2007, 06:46 PM
Darth ModerVader
Padawan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">Taking PS off DOES NOT GIVE HORSE-POWER YOU HP-HUNGER...yes, it does free up the power of your drivetrain</TD></TR></TABLE>
So which is it?
Removing the power steering (or even simply the PS pump belt) has been dyno-proven to free up anywhere from 4-7 whp on on a B-series. Whether or not you can personally detect that power difference, it's still there.
Old 05-16-2007, 06:48 PM
tdizz07's Avatar
i def am starting to regret taking my ac out of my car. but i woulda had to get the del sol bracket and crap, im just too lazy and i always have my windows down anyway
Old 05-16-2007, 06:51 PM
Darth ModerVader
Padawan's Avatar
Default Re: power steering (tdizz07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdizz07 &raquo;</TD></TR><TR><TD CLASS="quote">i def am starting to regret taking my ac out of my car.</TD></TR></TABLE>
I can certainly understand that. Even in the Northeast, there are times when I wouldn't want to be without A/C.
Johnoolo
12-29-2018 03:11 PM
ray.riddler92
05-24-2011 06:08 PM
BigECivic
04-13-2006 12:27 PM
Hatch It
05-14-2004 08:56 AM
TypeR Sanders
01-28-2002 09:11 AM
Quick Reply: power steering
