p1457 error code
Old 02-19-2008, 01:29 PM
sdfghjkqwer's Avatar
Default p1457 error code
I got the p1457 on my 99 civic ex
Whats the best place to take for a diagnosis? I am located in boston, massachusetts area. Dealership quoted me $100, is it a good price? Can I trust them?
Any help is appreaciated, thanks.
Old 02-19-2008, 01:33 PM
SilverBulletY8's Avatar
Default Re: p1457 error code (sdfghjkqwer)
any local parts dealer should be able to hook into you ECU and pull codes... many will do it for free...
Old 02-19-2008, 01:35 PM
98CivB18C's Avatar
Default Re: p1457 error code (SilverBulletY8)
take it to the zone, auto zone
they check your CEL for free
use red search button on the top for CEL codes.
Old 02-19-2008, 02:23 PM
nub
nub's Avatar
Default Re: p1457 error code (98CivB18C)
p1457 evap system leak canister area-- look for cracks on the canister disconected or damaged lines
Old 02-19-2008, 08:00 PM
Thanks for all the replies
I know its the canister..Unfortunatelly i dont have a lifter, tools or time to look at it my self. Whats the best place to check for leaks?
Old 02-19-2008, 10:24 PM
H-T White Ops
NOFX's Avatar
Autozone is selling an OBDII scanner for $40 right now too. (Regular price is $69.99.) It's just a basic model that reads the code (no explanation on the screen) and erases codes, but it works.
It comes with a book with explanations for all the codes.
But yes, they will scan your car for free too. Then they'll give you a little print out that says what the code is, what it means and the most common problems that cause that cell.
Old 02-27-2008, 11:32 AM
Ok I found the problem and I replaced the 2 way valve.
Almost 300 miles passed and the light didn't go on.
Is it safe to take the test?
Old 11-30-2011, 09:35 AM
koreboy's Avatar
Thanks for the info!
How did you know it was the two way valve that was causing the problem?
I have the same code and the mechanic at the Honda dealership told me that this error would not harmfully affect my engine.
Old 11-30-2011, 09:51 AM
Shooktd's Avatar
where did you get the valve? part number? i need the same one
Old 12-23-2011, 06:49 PM
lawnguybri's Avatar
Lmao...I'm there too. How can the two way valve be tested? And where do I find one?
Old 12-24-2011, 04:07 AM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/evap-emissions-p1457-check-engine-light-99-civic-si-2558768/
professorman
02-10-2014 04:29 PM
jillygirl13
Honda CR-V & Element
06-11-2012 06:25 PM
iconz116
01-08-2005 12:20 PM
Nighthawk GS-R
10-05-2001 10:05 AM
Quick Reply: p1457 error code
