Car Wont Start / Idles Rough...Need help
Old 12-04-2009, 08:32 AM
tedo2007's Avatar
Default Car Wont Start / Idles Rough...Need help
Car wouldnt start last night at the gas station, after several minutes of trying, i finally got it going, drove it home no problems...
then today i go out, wont start at all (turns over, just like last night) but wont start
so i removed the negative cable, waited a bit hooked it back up, now it starts, but it does this
http://www.youtube.com/watch?v=_ww1RD-QPfc
very rough start, once it starts it runs just fine....
main relay must be good, i hear it clicking as well as the fuel pump!
Old 12-04-2009, 08:34 AM
Former User's Avatar
Default Re: Car Wont Start / Idles Rough...Need help
Any CEL codes?
Old 12-04-2009, 08:36 AM
tedo2007's Avatar
no codes....
Old 12-04-2009, 08:37 AM
Does the CEL work -- on for 2 seconds and then off when key is turned to ON(II)?
Old 12-04-2009, 08:39 AM
tedo2007's Avatar
yep, i had a cel a couple weeks ago for my o2 sensor, changed it out...
after that rough start, itll stay running no problems...
cap? rotor? or would that not do that?
Old 12-04-2009, 08:40 AM
How old are the plugs, wires, cap, and rotor? Have you inspected them?
Old 12-04-2009, 08:41 AM
tedo2007's Avatar
plugs 2 weeks old
wires, 6 months
cap and rotor - never changed or inspected
Old 12-04-2009, 08:43 AM
Originally Posted by tedo2007
plugs 2 weeks old
wires, 6 months
Definitely pull the cap off and inspect the inside contact points as well as the corresponding contact on the rotor. Post pictures if you can.
Old 12-04-2009, 08:45 AM
tedo2007's Avatar
i will say, when i tried to start it at the gas station when it wouldnt start, it was like it just turned over and finally it did what you see in the vid, and started
Old 12-04-2009, 08:46 AM
tedo2007's Avatar
whats the easiest way of getting the cap off? its alot easier on a 440 big block
assume its the 3 screws? the one looks hard to get to..lol
Old 12-04-2009, 08:48 AM
Just remove three bolts to get the cap off:
Old 12-04-2009, 09:07 AM
tedo2007's Avatar
http://www.youtube.com/watch?v=6Kq3gTSQU0I
Old 12-04-2009, 09:08 AM
tedo2007's Avatar
both look very worn, would that cause my problem?
Old 12-04-2009, 09:58 AM
tedo2007's Avatar
thanks man, i owe you a million, ....changed the cap and rotor, runs like it never has since i bought it a year ago!
95blackEG
12-29-2008 12:44 PM
ek_b16
09-07-2005 10:35 AM
jdmtim
11-11-2003 04:32 AM
Honda Sport
06-04-2003 05:27 PM
Quick Reply: Car Wont Start / Idles Rough...Need help
