P0135
P0135
Hello all,
So my dx threw the MIL light a couple days ago and im able to scan codes at home and P0135 was the culprit. Fast forward to today, i replaced the 02 with a Denso replacement ONLY because i wasnt having the speedo issue/etc that came with the popular blown fuse. I pull the 7.5 Backup fuse to reset the code and the code returned 5 seconds after start up. Should I let the car go through some warmup cycles or does my problem run deeper?
Re: P0135
welp its busted. gotta do the TSB. Although I went out and bought another couple 7.5A fuses and they are too big. Annoying. I grabbed ATO size fuses and I'm assuming the 7.5A Fuse 15 is a "mini fuse"?
Re: P0135
im pretty sure they are but if not why not got to the parts store, pull one or take the blown one and just compare them inside the store.
you said u got the wrong ones, if ur returning them then might as well do it all in one trip
Cdeese910
10-25-2012 07:56 AM
