Overfilling tranny fluid?
Old 04-27-2006, 07:17 AM
TurboEM1's Avatar
Default Overfilling tranny fluid?
What would happen if you overfilled your manual tranny? Would the excess some how get burned off or dumped somewhere or would it stay in the tranny? Any side effects to having an overfilled tranny? I am not talking quarts more but like .5 quarts at most. Thanks
Old 04-27-2006, 07:28 AM
HatchEh2's Avatar
Default Re: Overfilling tranny fluid? (TurboEM1)
its almost impossible to over fill a tranny. the fill port is on the side... and its also the level check port... you just fill it till it starts to seep out and your good... if theres too much itll pour out, your fine.
what makes your think you overfilled your tranny?
Old 04-27-2006, 07:36 AM
t0p_sh0tta's Avatar
Default Re: Overfilling tranny fluid? (HatchEh2)
It's very possible to overfill the tranny if going through the VSS. It's much easier than fiddling with a flex-funnel or whatever.
However, if filling from the proper fill hole, the tranny shouldn't be overfilled.
Unfortunately, I don't know what damage could be done by overfilling.
Old 04-27-2006, 07:41 AM
cyang08's Avatar
i need to flush and fill also. anyone know how many quarts go in a D series trany?
Old 04-27-2006, 07:43 AM
t0p_sh0tta's Avatar
Default Re: (cyang08)
Manual? About 2 quarts. Just fill it until it starts to pour back out.
Old 04-27-2006, 07:44 AM
HatchEh2's Avatar
Default Re: (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">Manual? About 2 quarts. Just fill it until it starts to pour back out.</TD></TR></TABLE>
correct,
ill vouche for that too.
Old 04-27-2006, 09:12 AM
TurboEM1's Avatar
Default Re: (HatchEh2)
I dont think i overfilled my tranny i am just curious. I always fill it from the side hole not through the vss or anywhere else. And yes I fill it untill it starts to seep out. When i do it the car is jacked up so its slightly unlevel but it is not enough to cause any major difference.
I was really just asking out of curiosity.
Old 04-27-2006, 09:45 AM
graveltravel2's Avatar
kiss your axle seals good bye.
thats what happened to me. you supposed to fill up to 1/2 inch from the fill hole itself.
now since my trans got over filled the whole underside of my car and exaust is covered with trans fluid. and it smells like **** too.
Old 04-27-2006, 10:06 AM
SuperSlow's Avatar
Default Re: (graveltravel2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel2 &raquo;</TD></TR><TR><TD CLASS="quote">kiss your axle seals good bye.
now since my trans got over filled the whole underside of my car and exaust is covered with trans fluid. and it smells like **** too.</TD></TR></TABLE>
not sure how you managed to do this... not sure how you know what 1/2 inch is either.
Old 04-27-2006, 10:20 AM
IHateJDM's Avatar
Default Re: (SuperSlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">
agreed. I have a feeling his axle seals would have gone either way.
what i ment by half inch is if youy stick your pinky finger down the fill hole, the fluid should touch the top of your pinky finger.
Old 04-27-2006, 10:25 AM
killerformula's Avatar
Honda made the fill hole on the trans just like they do on transfer cases. You stick a funnel in it, start dumping fluid in, and when it starts pissing back out on to the ground you screw the plug back in. I'm really not sure how anybody could fk that one up, and I'm sure that's what honda was thinking when they designed it that way. Unfortunately for my faith in humanity, it sounds like somebody managed to do just that.
A fluid level that is too high can cause excess "whipping" of the oil (this is why certain performance engines have "windage" trays). Because of this, actually more oil can result in less lubrication because its whipped more and full of bubbles.
K
Old 04-27-2006, 10:27 AM
SHG_Beans's Avatar
like a few others said, fill it from the side, when it starts to pour out, you're good to go. make sure the car is somewhat level. filling it from the side, you prettymuch can't over fill it. not sure what the hell you did gravel, you probably just needed axle seals anyway.
Old 04-27-2006, 10:28 AM
ek_chris's Avatar
if you fill it up over its fine.. its not going to hurt anything. But do what the others said, its the easiest way to fill your fluid
Old 04-27-2006, 11:14 AM
SuperSlow's Avatar
Default Re: (ek_chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_chris &raquo;</TD></TR><TR><TD CLASS="quote">if you fill it up over its fine.. its not going to hurt anything. But do what the others said, its the easiest way to fill your fluid</TD></TR></TABLE>
if doing it properly, unless you are not on a level surface, you cannot overfill....
Old 04-27-2006, 11:22 AM
cyang08's Avatar
what if you dont fill it from the side and just fill it from the speed sensor? can you over fill that way cause some people say its easier to fill from the speed sensor.
Old 04-27-2006, 11:26 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cyang08 &raquo;</TD></TR><TR><TD CLASS="quote">what if you dont fill it from the side and just fill it from the speed sensor? can you over fill that way cause some people say its easier to fill from the speed sensor.</TD></TR></TABLE>
you can fill it there if you don't have the right kind of funnel, but afterwards, I would open the fill hole and let any excess drain out.
Old 04-27-2006, 11:27 AM
cyang08's Avatar
Thanks very much lots of help.
Old 04-27-2006, 12:12 PM
basically what i made was a funnel with about 3.5 feet of hose attached to it. and ofcourse the hose goes in the gearbox fill hole. i used the clear hose.
Old 04-27-2006, 12:29 PM
H-T White Ops
Frozen E's Avatar
take out the VSS. Open the fill plug. Get a hose and start filling through the VSS hole. Keep an eye on the filler hole. If fluid starts coming out, stop (duuuhhhh). That's what I did last night.
Old 04-27-2006, 12:55 PM
SHG_Beans's Avatar
yeah its easier to fill from up top, but all you need is a piece of hose on the end of a funnel and do it from the side, on a level surface, and you CANT overfill. just do that.
Old 04-27-2006, 06:39 PM
TurboEM1's Avatar
Default Re: (killerformula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerformula &raquo;</TD></TR><TR><TD CLASS="quote">
K</TD></TR></TABLE>
Thank you that was the exact response i was looking for.
Old 04-28-2006, 01:06 AM
Elwuudz's Avatar
tranny fluid is a bitch to fill; however idiot proof
fill till it spills
i recommend lucas oil stabil in royal purple
or motul if u feel like going to the trouble
Old 04-28-2006, 04:09 AM
JimmyAtlantis's Avatar
Default Re: Overfilling tranny fluid? (Elwuudz)
You can't overfill your manual tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz &raquo;</TD></TR><TR><TD CLASS="quote">fill till it spills </TD></TR></TABLE>
^^^The proper way to do it.
TypeR1558
01-27-2004 04:03 PM
Brian-Brian
07-22-2003 08:56 PM
Quick Reply: Overfilling tranny fluid?
