Outer tie rod will it cause a clicking when braking?
Hey guys i think my outer tie rod is going bad when i brake i hear a clicking noise like my brake system is loose but i checked all of that. So when i brake it clicks is this a tie rod?
Re: Outer tie rod will it cause a clicking when braking? (Spence)
to check it:
with the vehicle up in the air...wiggle the wheel side to side...there should be NO play...meaning the wheel should feel tight and snug...no clicking or popping...if there is, you may have a bad tie rod...also check the upper and lower ball joints while you're at it too...makes finding the problem a hell of alot easier
Spence
Suspension & Brakes
07-18-2005 03:38 PM
