Oil light came on, bad oil pump?
This is a b18a1 in a 93 hatch. First started last night when I was driving the oil pressure light was blinking. Then today I am driving to school and the light comes on and it stays on, I am in 5th gear cruising and all of a sudden I rapidly start slowing down like the motor is locking up. Pull over and check oil and it is fine, open up the oil cap and theres all this white smoke in there... get it towed home and I take the valve cover off and it seems kinda dry in there, is this a bad oil pump?
Re: Oil light came on, bad oil pump? (LShatchie)
That's exactly what it is.
Happend to my second D16Z6. **** almost caught on fire on I-75. Hahaha.
Re: Oil light came on, bad oil pump? (diegoaccord)
same happened to me.
When I pulled motor apart, Oil pump gear had almost welded itself to the pump housing.
Also, #4 main bearing was so scared, crank was almost unuseable.
be professional
The oil light is triggered when pressure drops below 4.3 psi, which means that your engine is likely toast.
Re: Oil light came on, bad oil pump? (Targa250R)
so basically the reason why the motor seemed to be locking up was because the pump was locking up and no oil getting to the motor? I am guna change the pump out, hopefully it will be ok ... I mean it is a honda
Ive been searching and why is it that everyone who has had a bad oil pump, the pump actually shattered or broke? Im pretty sure mine hasnt shattered or anything
O.G. triple O.G.
Re: Oil light came on, bad oil pump? (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">same happened to me.
Also, #4 main bearing was so scared, crank was almost unuseable.</TD></TR></TABLE>Same with me...except for the welded part...LOL
O.G. triple O.G.
Re: Oil light came on, bad oil pump? (O16581724 5 2 5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">As soon as that light comes on, don't drive it until you find the problem.
</TD></TR></TABLE>Uhhmm..wut was the purpose of that pic...of your toast with jelly?
Electrician
Re: Oil light came on, bad oil pump? (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">Uhhmm..wut was the purpose of that pic...of your toast with jelly?</TD></TR></TABLE>
It means that if he drives it with the oil light on the engine will be toast. Get it? Hardee har har.
Re: Oil light came on, bad oil pump? (ThatsMyEG)
check what bearings? right now I have the timing belt of and oil pan droped and im about to take the oil pump off and take a look at it... looks like my timing belt might have skipped some teeth too .... this is bullshit... i just fully rebuilt my head and changed timing belt, water pump... everything besides bottom end
i don't care what happened, ur oil light cfame on oil wasn't being circulated, you might as well rebuild it, some thing goes for when its run without oil, best thing to do is to repair the bottom end now doing it right instead of waiting becuase it creates weak points and thats whats going to break, so do it right rebuild the bottom end, not terrebly hard to do just take ur time and do it right.
btw yea its a bad oil pump, common on d series i have lost 3 motors do it oil pumps on d series everytime i have just yanked the motor or rebuilt the bottom end
Re: Oil light came on, bad oil pump? (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">The oil light is triggered when pressure drops below 4.3 psi, which means that your engine is likely toast.</TD></TR></TABLE>
it is actually a different pressure.....hold on I will go to the ISIS Honda program and tell you exactly what it is
Re: Oil light came on, bad oil pump? (DirtySol)
Well my motor is not locked up and I dont see any metal shavings in the oil or anthing, what exactly is messed up on my motor now? I am not worried about the condition of the motor, I have another b18 siting in my garage right now being fully built for turbo, its just not done yet and I dont have the funds right now to finish it up quick enough to drop in... but yeah I cant get the crank bolt off, it must have seized to the oil pump gear
You n00b, those bolts are on crazy tight, put the car in 5th, have someone hold the brakes and jump on a breaker bar to get it off. It doesn't matter if your engine isn't locked, mine didn't lock either when my oil light came on, i was still boosting it until i started losing so much power it wasn't fun anymore (which only took a few hours), then i rebuilt it, with another crank of course.
dont call me a ******* noob right now i am not in the mood, I know exactly how tight these bolts are, I have removed them plenty of times, but this bitch is STUCK I tried my air tools, put a donut on the car lowerd it, put in 5th gear, slammed on brakes, got like a 10 foot breaker bar and had my 200lb friend jump on it, and the ****** is not coming off... i have spent all my dam money on this car and i really am not in the mood for some dumbass **** talking on the internet... i made this post to try and get answers, but this site has gone to **** cause of people like you
so what the **** is exactly happening when the oil pump takes a **** but it hasnt locked up ? sorry for the language but im pissed
I think what O16581724 5 2 5 is trying to say is the oil pump and the crank bolt are in no way related. I mean, in the sense that if the oil pump went bad, it would not cause the crank bolt to not come off. Excuse the double negative, but I think you get what I'm trying to say.
Anyways, the internet is not a crystal ball, we don't know what happened to your motor. That's why everyone is telling you to pull it apart and see for yourself. Worse case, get a block from the junkyard and just swap it in. It would prolly be the cheapest way to go.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LShatchie »</TD></TR><TR><TD CLASS="quote">so what the **** is exactly happening when the oil pump takes a **** but it hasnt locked up ? sorry for the language but im pissed </TD></TR></TABLE>
The first things to check are the main bearings and crank journals.
