obd1 alternator to obd2a alternator??
Old 11-04-2010, 07:57 PM
qpzm12's Avatar
Icon2 obd1 alternator to obd2a alternator??
i have a 92 civic. obd1 d16y8. stock d15b7 obd1 harness... does anyone know how to swap plugs ... like the wiring to use the obd2a plug on the obd1 harness ?? the alternator is a 99 ex... they are both 4 pin plugs if it matters
Old 11-04-2010, 08:49 PM
qpzm12's Avatar
Default Re: obd1 alternator to obd2a alternator??
anyone???
Old 11-04-2010, 09:32 PM
JDM4mee's Avatar
Hi there....
This will help you figure it out:
OBD2 - - - - - OBD1
black/yellow = black/yellow
white/blue = white/blue
white/yellow = white/green
white/red = blue
Overral whenever you are swapping or converting from OBD1 to OBD2 (ex. Distribuitor, Alternator, etc, color cables must of the times will match, but not always)
Good luck!
Old 11-05-2010, 09:32 AM
qpzm12's Avatar
thank you
Old 11-05-2010, 09:50 AM
Former Moderator
B18C5-EH2's Avatar
Have you thought about removing the voltage regulator from the old engine's alternator, and swapping it into the Y8's alternator housing? It's not hard, and would allow you to not hack/splice wiring at the alternator plug. It changes the plug on the alternator from round to square or vice versa.
I used to have a detailed write up, but I cannot find it. I have done this for B series swaps into 92-95 Civics. I don't see why it shouldn't also work for SOHC alternators.
Old 11-05-2010, 01:06 PM
Technical Hero
HondaPartsHero's Avatar
Old 11-06-2010, 05:47 AM
h22preludevtecx's Avatar
It's as simple as swapping that plug over and your pretty much good to go
SSBP-GSR
12-21-2018 10:06 PM
Alex Preece
10-03-2018 07:36 PM
Uniquerootz
10-02-2007 11:40 AM
DC2 Mang
04-18-2007 07:08 AM
lsvtechatch92
03-07-2007 06:44 PM
Quick Reply: obd1 alternator to obd2a alternator??
