Noob: how to bleed clutch '97 Civic
Old 09-28-2015, 04:56 PM
cowgirly's Avatar
Default Noob: how to bleed clutch '97 Civic
Hi all - first off, I have zero knowledge about cars.
Problem is my clutch won't engage - turns out the reservoir is empty. I bought clutch fluid and was told I have to bleed the clutch, but I can't find a video to show me how to do this. Anyone have any resources? I can't drive until I figure this out, so I need to do this ASAP, and I'm hoping this solves my problem so I don't have to take it to a mechanic. Thanks for your help!
Old 09-28-2015, 05:00 PM
Former User's Avatar
Default Re: Noob: how to bleed clutch '97 Civic
Have you tried to determine why the clutch reservoir has no fluid? For example, is there a leak? Do you see fluid staining on the carpet below the clutch pedal?
Old 09-28-2015, 05:13 PM
cowgirly's Avatar
Thanks, RonJ!
I figured the first step would be to fill it and bleed it, and (if that works and I can drive) then see if it leaks out. Then I'll know if there's a leak...
Just checked the car and there's no fluid stain below the clutch pedal.
Old 09-28-2015, 05:15 PM
Another place to look for a leak is the slave cylinder.
Old 09-28-2015, 05:21 PM
cowgirly's Avatar
Ok, if I can find out where that is I can look. I found this guide but the images are broken: OFFICIAL DIY: Replacing the Clutch Slave Cylinder (Leaking clutch fluid) | ClubCivic.com - Your Online Civic Community
Old 09-28-2015, 05:28 PM
This diagram should help you find the SC at the front of the transmission, and also instruct you on bleeding.
Old 09-28-2015, 06:02 PM
cowgirly's Avatar
Thank you. Any resources for bleeding the line? That's where I need to start. I still can't find anything online that shows me how to do that.
Old 09-28-2015, 06:03 PM
Bleeding the slave cylinder bleeds the line. That's where the the SC gets fluid.
Old 09-29-2015, 02:14 AM
Technical Hero
HondaPartsHero's Avatar
Old 09-29-2015, 02:21 AM
Stancetard Hate Monger
eghatch9295's Avatar
fluid doesnt magically disappear. its not if you have a leak, but where.
Jon Petersen
12-08-2018 04:51 AM
CraiGlOl
07-09-2009 07:52 AM
always smooth
01-25-2008 10:19 AM
OSG 97 ITR
04-17-2004 10:11 AM
type_sml
08-23-2002 12:53 PM
Quick Reply: Noob: how to bleed clutch '97 Civic
