o2 sensor??
Old 02-19-2007, 09:17 AM
team 15's Avatar
Default o2 sensor??
My brother has a 97 civic hb with a d16y8 motor swap. The code its throwing is 65 which is the secondary o2 sensor. Do the d16y8 have a secondary o2 sensor? If so, i don't see any secondary o2 sensor on my brother's car, but there's an extra sensor that is not plug. It's near behind the block. It has two pin. Could that be it?
Old 02-19-2007, 09:19 AM
HT White Ops
Eran's Avatar
The O2 sensor is going to be a four-wire (I believe). It's in your cataltyic converter, which is in the exhaust, after the exhaust manifold. It's located under the car under the shifter.
Old 02-19-2007, 09:53 AM
HT White Ops
Eran's Avatar
Default Re: (JJSpecTuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning &raquo;</TD></TR><TR><TD CLASS="quote">96-00 hatchback's never came with a d16y8, only d16y7
on the d16y8, the secondary o2 is under the driver, INSIDE THE CATALYTIC CONVERTER
on the d16y7, the secondary o2 is in front of the block, INSIDE THE CATALYTIC CONVERTER WHICH IS RIGHT THERE WHEN YOU OPEN THE HOOD
depending on which manifold he's running
Read. He's got a swapped engine.
Old 02-19-2007, 04:43 PM
team 15's Avatar
Default Re: (Eran)
I don't see any other 4 wire sensor except 2 wire sensor.
Old 02-19-2007, 04:49 PM
HT White Ops
Eran's Avatar
It may be two wire, I can't remember. There should be a sensor sticking out of your catalyic converter. If the plug fits, then stick it in.
Acirimis
11-30-2016 05:33 AM
crazyhtch
01-16-2006 09:43 PM
silentblackhat
02-15-2005 10:33 AM
Hatebreed215
03-09-2003 08:11 PM
Quick Reply: o2 sensor??
