Brakes, fluid, problem
Old 02-24-2004, 04:57 PM
pimpwok's Avatar
Default Brakes, fluid, problem
I've had to fill up my brake fluid three times in the past couple of weeks. The first time i was really low so i went out and bought a small bottle of that Valvoline Synthetic brake fluid. The other two times have been similar. From what the bottle says, the synthetic stuff is better than both DOT3 and DOT4 fluids, but it doesn't mention whether or not it mixes with regular DOT3/4's. Now my question, is the synthetic stuff ok to mix with regular DOT3/4's? or do i have a leak?
Old 02-24-2004, 05:00 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Brakes, fluid, problem (pimpwok)
Yes it mixes and yes, you probably have a leak.
Old 02-24-2004, 05:47 PM
Yeung's Avatar
you have a leak.. you can't use up your brake fluid unless you have a leak
Old 02-24-2004, 05:58 PM
pimpwok's Avatar
Thanks
so a solution would be?
Old 02-24-2004, 06:03 PM
Chiovnidca's Avatar
Default Re: (pimpwok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpwok &raquo;</TD></TR><TR><TD CLASS="quote">Thanks
so a solution would be?</TD></TR></TABLE>
Find and repair the leak?
Old 02-24-2004, 06:08 PM
pdiggitydogg's Avatar
probably easiest to just check your bleeder screws and go from there along all the lines to the prop valve and then to the mc
Old 02-24-2004, 07:03 PM
ricky1969's Avatar
yes, exactly what everyone is telling you. You have a leak.
kommon_sense
01-04-2005 11:46 AM
PatrickGSR94
05-07-2004 07:37 PM
blkgsr03
04-16-2004 09:21 AM
drjondurst
10
08-26-2003 10:19 AM
Flux
10-06-2001 12:07 PM
Quick Reply: Brakes, fluid, problem
