LS/VTEC pinging noise
Old 08-09-2005, 02:26 PM
christhereefer's Avatar
Default LS/VTEC pinging noise
Recently I started hearing a pinging noise coming from the head in my motor. The pinging noise rattles at around 2-3K, even with no load. After the engine warms up and I try to start it again, it'll ping on start up. Checked timing and everything is set. Tried retarding the timing on the distributor all the way, it helped a little bit, but I could still hear the pinging. Anyone know what it could be?
Setup is B18B block with P30 pistons. Head is stock B16 from 99 Si. Compression is at 11.5 with this setup. I also run 91 octane.
Modified by christhereefer at 3:39 PM 8/9/2005
Old 08-09-2005, 02:27 PM
EK k kay's Avatar
Default Re: LS/VTEC pinging noise (christhereefer)
Pinging like marbles in a glass jar? Sounds like detonation.
Old 08-09-2005, 03:09 PM
Default Re: LS/VTEC pinging noise (wadup)
What could be causing it to detonate?
Old 09-08-2005, 12:33 AM
MenaceL.A.671's Avatar
got the same problem! same set up too...
ay_billy
07-08-2012 12:45 PM
superhatchbackbros
10-06-2010 03:49 PM
joshblaze101
08-26-2009 09:02 PM
joey1320
04-12-2005 08:10 AM
93SSPHatch
06-04-2002 09:24 AM
Quick Reply: LS/VTEC pinging noise
