ls/vtec into 99 civic ex several questions
Old 10-24-2010, 10:09 AM
rippintec's Avatar
Default ls/vtec into 99 civic ex several questions
ok so i have a ls/vtec that im trying to swap into my 99 civic ex. so far i have a p72 gsr ecu alternator off 99 gsr and wiring harness off same gsr. my questions are which t bracket do i need and which wiring harness do i need? cuurently the car has a d16z6 which i believe has all the old stuff (ecu is a p2p, injectors, harness, and alternator from the motor which originally came in the car.
rippintec is offline
Old 10-24-2010, 10:15 AM
Seagull Management
94EG8's Avatar
Default Re: ls/vtec into 99 civic ex several questions
You'll need to reuse the EX harness and add the wiring for the IABs if you want them to work, you will also need to swap the distributor plug. If it was me i'd get the plugs off a '96 - '98 Y7 harness, its kind of a waste to cut up a good GS-R harness for a couple of plugs, especially when you can sell it and get some money.
T bracket needs come from a '99 - '00 Si, you will also need a 2 post driver's side mount from the same.
94EG8 is offline
Old 10-24-2010, 10:18 AM
devney's Avatar
I could be wrong but I'm almost positive you need a t bracket from a 99-00 SI. As for the harness you can't use the gsr harness, but you can use the harness that you are currently using. You may have to do a little wiring.
edit: 94EG8 beat me to it
devney is offline
Old 03-28-2012, 08:32 PM
hondanerd87's Avatar
def gotta use the 99-00 si t bracket i jus went through that and the top post mount drivers side for the 99-00 si and def use the ex harness itll save u $
hondanerd87 is offline
Old 03-29-2012, 03:45 AM
Seagull Management
94EG8's Avatar
This thread is 2 years old.
94EG8 is offline
Cprace1
09-12-2005 09:50 AM
blackie
07-17-2005 01:31 AM
Se-rv-Tak
02-21-2004 09:13 PM
EX-T
10-02-2003 03:36 AM
FBP Si 2000
06-12-2002 03:01 PM
Quick Reply: ls/vtec into 99 civic ex several questions
