Keep ABS with OBD1 (P28) ECU conversion?
Old 03-26-2017, 10:23 PM
petr0lb0mb's Avatar
Default Keep ABS with OBD1 (P28) ECU conversion?
Sorry if this is a stupid question...
I'm transferring my B16a2, p28 ECU and harness from my EM1, into a 99 Civic EX with ABS. I WANT TO KEEP ABS in the new swap. Is it possible? Is there anything special I will need to do?
All along, I've been assuming that it won't be a problem, but now that I'm close, I'm starting to worry. LOL
FWIW, I see that my ECU (P28-L51) was originally offered for 92/93 Civic EX w/ ABS.
Old 03-26-2017, 11:49 PM
Black R's Avatar
Default Re: Keep ABS with OBD1 (P28) ECU conversion?
Abs is independent of Ecu.
It has it's own brain and wiring.
Old 03-27-2017, 12:50 AM
petr0lb0mb's Avatar
Thank you! I wasn't sure if the ECU played any role. Now I can sleep. =D
Old 03-28-2017, 11:43 AM
Oh look, I can change this
deschlong's Avatar
Only has a role if the car has TCS or is INTRAC 4WD. Other than that, you're golden.
Old 03-28-2017, 12:26 PM
Black R's Avatar
He posted in the eg / ek forum, so...
Old 03-28-2017, 12:44 PM
deschlong's Avatar
So ... Yep, it's only super rare models that have TCS or INTRAC!
Old 03-28-2017, 05:40 PM
petr0lb0mb's Avatar
The only traction control my car has is the torque limitations of the stock N/A B-16. So, I guess I'm golden. Haha!
Cruiserdude
05-13-2019 08:20 AM
stryker gs
08-28-2012 09:12 PM
HYREV2NR
07-29-2003 12:45 AM
FormulaEJ8
02-08-2003 02:12 PM
Quick Reply: Keep ABS with OBD1 (P28) ECU conversion?
