Jdm Gsr Coolant in oil.
Old 05-16-2012, 10:06 PM
B16a2Em1's Avatar
Default Jdm Gsr Coolant in oil.
Alright guys, I have a Jdm gsr that's swapped into a 99 si. It is somehow leaking coolant into the block. The oil in oil pan is a creamy milky substance. I've searched that it could be a blown head gasket. My coolant reservoir is clean and there is no mixing there. The gsr was on my other si before i put it into my new si, before putting it into the new si, i swapped on a blox intake manifold and i think that's how it might be getting into my block? There is no white exhaust. I checked the gasket twice and re torqued the manifold to specs. Before installing the blox manifold, it did not do this, and ran strong, no oil mixing, so that's why i do not think that it's a blown head gasket. Ordered from Hmotors (40-80k mi)and it did not smoked what so ever before Swapping it into new si and blox manifold install. Also heres a diagram on how i did my coolant hoses. Did i do put a hose wrong somewhere? Help please HT!
Old 05-17-2012, 07:13 AM
motegicivic's Avatar
Default Re: Jdm Gsr Coolant in oil.
Did you double check all of the lines going to manifold? You def have the right mani? Did you replace the gasket?
Old 05-17-2012, 09:23 AM
idreamidrive's Avatar
Pressurizing your cooling system is quickest way to figure out this one.
Old 10-24-2012, 04:17 PM
civicracer876's Avatar
What happened to this thread I need answers I am having the same exact problem
jspinelli8
03-26-2018 01:31 AM
jake28
Honda Civic (2001 - 2005)
01-15-2014 10:06 AM
slowwcivic
04-10-2011 02:44 PM
dc2_dude
02-13-2009 12:12 AM
daniel990836
04-16-2008 08:30 PM
Quick Reply: Jdm Gsr Coolant in oil.
