1995 Civic Idle And Running Issue (Help)
Old 08-24-2021, 01:24 AM
Tommyz's Avatar
Default 1995 Civic Idle And Running Issue (Help)
it’s a 1995 civic low compression (was turbo built and back to stock now)
Has anyone experienced with this issue?
Cold start idling up and down very rough,
When the engine is warm up, Idle get stable and running at 1400rpm. A few small limps every 3 seconds during the idling but no up and down anymore when it’s warm already .
Giving it 20% gas throttle makes the limp even worse like up and down and if I open the throttle a little more it’s revving fine with no limit , However the engine sound hoarse .
-NO CELS . Check engine light works fine.
I took a vid of it
https://youtu.be/FXf64MXa1vY
Old 08-25-2021, 08:57 PM
Hysterically Calm
TomCat39's Avatar
Default Re: 1995 Civic Idle And Running Issue (Help)
Why would you think a stock ECU can run a low compression motor designed for forced induction?
Old 09-07-2021, 01:41 PM
Tommyz's Avatar
I already heard about many people it actually works for them with no issues.
this morning I replaced the IACV and O2 sensor , problem isn’t gone.
Nic0807
Honda Civic (2001 - 2005)
12-04-2018 08:50 AM
babohyungjin
09-19-2010 07:43 PM
stefanne3
01-29-2007 09:18 AM
cdx280
09-01-2005 08:45 PM
Quick Reply: 1995 Civic Idle And Running Issue (Help)
