Idle Issues, again....
Old 03-22-2006, 01:28 PM
mikeunreal2's Avatar
Default Idle Issues, again....
Update!! More idle problems...
My car is sputting at idle. My idle ranges from 200 to 1500, its not surging up and down up and down, but it varies. Its idle rough, and it dips down to like 200 and almost stalls out. I can hear it puttering out the exhaust. My steering wheel seems to shake when it idles and it just feels really rough. Im so confused!!! Im not sure what is causing this or what to do. Possible things causing this:
Car out of Time
Running too Rich (which I am)
Vaccum Leak
Im sure there are more but thats all i can think off at the time. PLEASE help me figure out this annoying problem!!!!
Ive tried cleaning my iacv, no use. Help!!!
Old 03-22-2006, 01:32 PM
funk2244's Avatar
Default Re: Idle Issues, again.... (mikeunreal2)
Have you checked your Throttle Position Sensor? I know my car was having erradic idle issues and it ended up being related to the tps.
Also does your car idle high when it is cold? If it gets messed up even when it is cold you might want to check out your fast idle control valve.
Old 03-22-2006, 01:37 PM
Lewy. Dee Ayy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeunreal2 &raquo;</TD></TR><TR><TD CLASS="quote">Update!! More idle problems...
Car out of Time
Vaccum Leak
Ive tried cleaning my iacv, no use. Help!!!</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1568459 sounds alot like my problem..check out my thread..it has a vid
Old 03-22-2006, 01:55 PM
byronl's Avatar
Default Re: Idle Issues, again.... (WhiteOut)
i just did a tranny conversion and now i'm getting this problem too! Bump for an answer
Old 03-22-2006, 02:33 PM
Default Re: Idle Issues, again.... (byronl)
sounds exactly like my problem. I get alot of puttering and backfiring out my exhaust. Amongst over things.
Old 03-22-2006, 05:01 PM
anyone else think its a timing issue?
Old 03-22-2006, 05:16 PM
btleier's Avatar
could possibly be timing... does the car drive like it should, or does it not feel right while driving as well?
Old 03-22-2006, 06:51 PM
CaliCleanMachine's Avatar
bump for the same problem
Old 03-23-2006, 04:07 AM
Default Re: (CaliCleanMachine)
cant remember, havnt driven it in a couple of days
Old 03-23-2006, 05:02 AM
sicones's Avatar
Default Re: (mikeunreal2)
what car is this exactly??
Old 03-23-2006, 11:56 AM
btleier's Avatar
Default Re: (sicones)
well go drive it... that would be helpful to know.
Old 03-23-2006, 12:00 PM
ITS_Dunn's Avatar
Default Re: (btleier)
agreed. if its still running rough while driving it, its probably internal.
things to go over:
throwing ANY codes?
check map sensor (make sure its on a REAL vacuum line)
TPS sensor could be screwed (swap throttle bodies real quick, might show difference)
IAC valve could be clogged or need to be screwed in and then backed off 1/4 turn.
dc4b20
22
12-03-2012 09:54 PM
typer_696
08-08-2009 01:43 PM
JSR
05-17-2006 10:27 PM
blackZC (W)
06-21-2004 05:58 AM
Tw1n Turb0 Z
10-18-2003 07:23 PM
Quick Reply: Idle Issues, again....
