IACV Diagnosis
Old 02-10-2011, 08:41 AM
66novass327's Avatar
Default IACV Diagnosis
I have a 94 Civic DX 1.5 16 valve. For quite sometime now my idle surges up and down once the car is warmed up. I have cleaned the valve a couple of times and it hasnt helped. Recently I decided to try something. Once the car was warmed up I unplugged the valve and it stopped idling up and down. Then plugged it back in and the idle was still fine but the engine light obviously came on and I drove it about 10 miles and parked it. The idle stayed normal. I then shut the key off and started it back up 5 minutes later. The engine light went out and it immediately started idling up and down again. So I repeated everything i did and it did the same thing. Once I shut the key off and turn it back on the light goes out and starts idling up and down. For some reason when I unplug it the idle goes fine and the light comes on but once I shut the key off and start it back up and the light goes out it starts all over again. Any ideas if this could actually be a bad valve or is it something else?
Old 02-10-2011, 08:54 AM
DaOne54's Avatar
Default Re: IACV Diagnosis
In for an answer. Mine seems to have this happend SOMETIMES. And when it happens its always after its up to normal temperature.
Old 02-10-2011, 09:14 AM
Former User's Avatar
1) Bleed the cooling system.
2) Test the ECT sensor and the TPS.
Vtec_India
16
02-06-2016 12:14 AM
dustinbs144
01-31-2011 07:18 AM
Touge Tuning
02-25-2009 08:28 AM
fraknstien
07-26-2007 07:51 AM
boonacka
10-08-2002 07:47 AM
Quick Reply: IACV Diagnosis
