How to tighten?
Old 05-05-2005, 01:51 PM
hondaracing1's Avatar
Default How to tighten?
how do you tighten the pulley that the alternator belt and power steering belt are on?
Old 05-05-2005, 02:05 PM
greenblurr93's Avatar
Default Re: How to tighten? (hondaracing1)
i'm assuming you're talking about the Crank shaft pulley... if so the take you tire off put it in 1st gear, have a friend press the break pedal as hard as he can, then with a 1.5 foot extension and a torque wrench, tighten to spec.
Old 05-05-2005, 02:15 PM
Default Re: How to tighten? (greenblurr93)
what should i set it to on the torque wrench?
Old 05-05-2005, 02:55 PM
what ever the service manual says to, my b18c1 is 130 ft/lbs.
Old 05-05-2005, 06:59 PM
the key was tore all to hell and the bolt is striped some a little under the washer. Im hoping i dont need a new crankshaft just a new pully, bolt and key
Old 05-05-2005, 07:35 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenblurr93 &raquo;</TD></TR><TR><TD CLASS="quote">i'm assuming you're talking about the Crank shaft pulley... if so the take you tire off put it in 1st gear, have a friend press the break pedal as hard as he can, then with a 1.5 foot extension and a torque wrench, tighten to spec.</TD></TR></TABLE>
That technique will not work and I'll tell you why:
First the brakes are connected to the axles which are connected to the tranny which is connected to the engine soley through a clutch(which is the weakest link). When you start to turn the engine crank pulley, even if you have someone step on the brakes as hard as they can. They engine will still move because the clutch cannot hold onto the engine due to slippage. There is nothing that will hold the clutch in place to prevent the engine from moving.
Here is 2 ways to do it: ghetto and the right way.
Ghetto way aka shadetree style: wedge a flat head screwdriver between the flywheel and the block while having someone break the torque off the crank pulley bolt.
The right way: use tool and you'll be done in no time: http://store.summitracing.com/...h.asp
Old 05-06-2005, 09:25 AM
Default Re: How to tighten? (Lord Helmet)
ok, i see your point, but this is how i did mine, and it worked perfectly.
Old 05-06-2005, 05:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenblurr93 &raquo;</TD></TR><TR><TD CLASS="quote">ok, i see your point, but this is how i did mine, and it worked perfectly.</TD></TR></TABLE>
Yes that's possible but if the pulley bolt is on there tight like factory "never been removed" tight then that way will not work. The right way is through the use of the factory pulley tool, Moroso's alternative and cheaper pulley tool, or the ghetto way.
hspoon
06-25-2016 09:40 AM
carlos8
04-10-2015 05:32 PM
California98Civ
08-09-2014 10:14 PM
go'in crazy
09-03-2009 12:00 PM
LeonardDB
11-21-2005 05:28 AM
Quick Reply: How to tighten?
