How to strip paint off a valve cover?
I have a B18a and the douches that had it before me painted the valve cover type R-ed. So how did you go about stripping the paint off the valve cover? Also, how do I polish it? Thanks for the help.
Re: How to strip paint off a valve cover? (EF9_SiR)
I bought my valve cover to a local powder coating shop and they sandblasted it and recaoted it for only $50. if you can find someone with a blaster i would do it that way. Airplane stripper works but it's gets messy.
New User
Re: How to strip paint off a valve cover? (jz98ctr)
Re: (NAEBP00Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAEBP00Si »</TD></TR><TR><TD CLASS="quote">to remove the paint use aircraft stripper....it just kinda bubbles off....as far as polishing I dunno....</TD></TR></TABLE>
That's what I used and it worked great
make sure u wear gloves when using the paint stripper thing. ive used it before on my rims, and that ish burns big time. it can take off piant, imagine what it doing to u!
Re: (stripes777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stripes777 »</TD></TR><TR><TD CLASS="quote">make sure u wear gloves when using the paint stripper thing.</TD></TR></TABLE>
and light that **** on fire
Re: (Doctor CorteZ)
If you want to polish it yourself, you can use an attachment to your drill or die grinder that is a SEWN buffing wheel. NOT a car polishing pad. They make different grades of compound depending on what you want to achieve. I just got the one that says "removes surface imperfections" and ought to be pretty rough. Start with that and finish with the Fine to achieve a "high lustre"
After paint removal, of course.
