how to remove heater controls 96 civic
Some of the bulbs are burnt out and I wanted to remove the heater controls and replace the bulbs
I removed the 2 screws underneath
how do you get this unit out?
The Grumpiest
Re: how to remove heater controls 96 civic
Someone posted this not one week ago.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-replacement-climate-controls-bezel-96-98-civic-2884447/
Once you get this out the rest is easy.
pop out the defrost and emergency flasher buttons.. they come out with the triangle plastic surround.
there are a couple more screws back there.
and if the radio/dash has never been out before...
then undo the glove box and the panel below the steering column, remove the center console, then undo the panel that holds the cig lighter. then look up under the radio straight from the bottom and get that one damn bolt that makes it so when they steal your radio they **** up every part of the dash in doing so. oh and since it is a 96.. undo the heater vent cable from the bottom of the hvac box.
F$%&ing thieves.
https://honda-tech.com/forums/showthread.php?t=2884447
hondaon18's
13
12-26-2008 06:12 AM
k.
10-10-2002 10:05 PM
