How often do you rotate ur tires???
Old 01-01-2006, 03:22 PM
Project_EK's Avatar
Default How often do you rotate ur tires???
What up,
I just got some new rubber so i wanna try n keep em as fresh as possible. my car is lowered about 3 inchs BTW! i was thinking like every 3 weeks?!?!
lemme know
Old 01-01-2006, 03:28 PM
EGDC2CIVIC's Avatar
Default Re: How often do you rotate ur tires??? (EKhatch219)
i rotate mine every other oil change, so 5500- 6000 miles
Old 01-01-2006, 03:37 PM
JunY's Avatar
I do mine every Oil change.
Old 01-01-2006, 03:47 PM
dohcVTECeg2's Avatar
Default Re: How often do you rotate ur tires??? (JunY)
i usually do it everey oil change as well. i like doing all that **** at once while im working on my car
Old 01-01-2006, 03:48 PM
Draggin99Si's Avatar
Default Re: How often do you rotate ur tires??? (dohcVTECeg2)
every 6k miles
Old 01-01-2006, 03:49 PM
95sivee's Avatar
Default Re: How often do you rotate ur tires??? (Draggin99Si)
do you have camber kit on your car?
Old 01-01-2006, 03:51 PM
The_Head's Avatar
Default Re: How often do you rotate ur tires??? (EGDC2CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGDC2CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">i rotate mine every other oil change, so 5500- 6000 miles</TD></TR></TABLE>
+1
Old 01-01-2006, 04:14 PM
Royal_C!ty's Avatar
Default Re: How often do you rotate ur tires??? (The_Head)
I dunno i guess call me a lazy, i rotate mine every other oil change lol
Old 01-01-2006, 04:15 PM
wushubrian's Avatar
Default Re: How often do you rotate ur tires??? (eg8kid)
I do mine twice a year.
Old 01-01-2006, 05:21 PM
civic_in_LA's Avatar
I never rotate my tires period. I just know that I replace my front tires more frequently than the back ones.
There really is no need to rotate tires. It just ensures that at the end you have to buy the four tires at one time.
I dont mind replacing two sets of front tires for every set of back tires.
Old 01-01-2006, 05:38 PM
EJ4door's Avatar
Default Re: (civic_in_LA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_in_LA &raquo;</TD></TR><TR><TD CLASS="quote">I never rotate my tires period. I just know that I replace my front tires more frequently than the back ones.
I dont mind replacing two sets of front tires for every set of back tires.</TD></TR></TABLE>
I do the same thing lol
Old 01-01-2006, 06:25 PM
old man neri's Avatar
This is only partly true. You are also suppose to rotate your tires left/right (unless they are directional) this compensates for any slight differences from one side to the next. The rear ones go straight to the front and the front ones go to the diagonally opposite corner.
If you have dropped your car 3" and don't have a camber kit rotating your tires will do nothing. It will wear down the inside of you tires regardless on what corner of your car they are on.
Old 01-01-2006, 06:28 PM
EX-T's Avatar
If you don't have a camber kit, I'd suggest getting one...it was one of my best investments towards my car...besides my cam...
Old 01-01-2006, 06:29 PM
wushubrian's Avatar
Default Re: (old man neri)
so true... please buy a camber kit cuz your going to spend more on tires anyways...
Old 01-01-2006, 06:54 PM
skrewdriver88's Avatar
Default Re: (wushubrian)
Every other oil change
Old 01-01-2006, 07:11 PM
JDMlyfestyle's Avatar
i jsut keep the back ones and burn off the front ones.. once the front ones are gone and i get new fronts and put em on the back
Old 01-01-2006, 07:13 PM
Ricey McRicerton's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">i jsut keep the back ones and burn off the front ones.. once the front ones are gone and i get new fronts and put em on the back </TD></TR></TABLE>
Haha, you guys are either on to something, or lazy as ****.
I do mine (front to back because they're directional) every 6-8k.
Old 01-01-2006, 07:27 PM
wushubrian's Avatar
It all depends on how you want to drive and change your tires....
Old 01-01-2006, 07:29 PM
cambopheonix56's Avatar
Default Re: How often do you rotate ur tires??? (wushubrian)
6k
Old 01-01-2006, 07:30 PM
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
I do mine (front to back because they're directional) every 6-8k.</TD></TR></TABLE>
well i got Summer and winter tires..
and i barely put 8k mileson my car a year
Old 01-01-2006, 07:57 PM
robert_v's Avatar
i never rotate mine either. its been like 1 year and 6-8 months since i bought new tires and they are still in great condition (no camber kits either)
Old 01-04-2006, 10:04 PM
Yeah really, there is no need to rotate tires.
I had my car since it was new, in 97, and never did I rotate tires. The whole tire rotation thing is a scam and big conspiracy.
Im running on stock tires, they are cheap as **** and not rotating them has no negative impact on them. Like I said, only the front tires get replaced first. Then keep an eye out and eventually the rear ones will go.
Old 01-04-2006, 10:12 PM
anony95ex's Avatar
Generally, in FWD (and some FWD-based AWD vehicles), rotate them every oil change. FWD really eats up the front tires, and rotating them will actually increase the time between tire purchases. Sure, you'll probably have to buy all 4 at one time, but why buy an extra pair of fronts when they could last until you need all 4 if they're rotated? With RWD vehicles (and most RWD-based 4WD trucks), you can rotate every other oil change (or even less frequently) and be fine. FWD is, IMO, one of the worst design traits to ever hit cars...unfortunately it's so common that finding a RWD car is actually a PITA. It's great that several manufacturers (most notably Chrysler) are going back to a basic RWD layout...damn I hate FWD, I drive it because there's no other choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">This is only partly true. You are also suppose to rotate your tires left/right (unless they are directional) this compensates for any slight differences from one side to the next. The rear ones go straight to the front and the front ones go to the diagonally opposite corner.</TD></TR></TABLE>
That's with older bias-ply tires. Radial tires, directional or not, are supposed to be rotated front-to-back, not crossed. It can cause uneven wear and slipped belts inside the tire, I've seen that happen too many times when people cross-rotate radial tires.
Old 01-04-2006, 10:21 PM
EK k kay's Avatar
Default Re: (anony95ex)
When you guys say "rotate tires" do you mean actually removing the tire and remounting it either in the opposite direction (non-directional tires) or onto another tire on the other side of the car (directional tires)? Or do you mean swapping the front wheels with the rear wheels?
Old 01-04-2006, 10:24 PM
anony95ex's Avatar
Default Re: (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay &raquo;</TD></TR><TR><TD CLASS="quote">When you guys say "rotate tires" do you mean actually removing the tire and remounting it either in the opposite direction (non-directional tires) or onto another tire on the other side of the car (directional tires)? Or do you mean swapping the front wheels with the rear wheels?</TD></TR></TABLE>
Just moving the wheels around on the car (usually front-to-back and vise-versa), it has nothing to do with removing the rubber tire from the metal wheel. If you walk into a dealership and ask for a tire rotation, this is what they're gonna do.
Quick Reply: How often do you rotate ur tires???
