how much would a shop charge to install lower control arms?
Old 10-13-2010, 10:46 AM
akcapr's Avatar
Default how much would a shop charge to install lower control arms?
Mine dont want to come off, the bolts are seized up. So im just wondering if anyone knows how much to expect for labor costs if i had a shop do it.. thanks
Old 10-13-2010, 10:47 AM
southernSCHEME's Avatar
Default Re: how much would a shop charge to install lower control arms?
no more than an hour or 2 of labor.. $150 tops
Old 10-13-2010, 10:48 AM
akcapr's Avatar
ok cool. and do i get charged extra if the bolts snap when theyre trying to take them out?
Old 10-13-2010, 10:56 AM
devney's Avatar
I'd just call a shop and ask them. Of course they're going to charge you more if it takes longer but it probably doesn't take them long since they have the tools.
Old 10-13-2010, 11:02 AM
ej6kid's Avatar
My lower control arm bolt was snapped. I work at adealer though so the tech did mine for free but it took all like 20 mins
Old 10-13-2010, 11:47 AM
TraptPatriot's Avatar
Get an angle-grinder, saw that bad boy off. Then buy a new one at the dealer, and install.
Or, use tons of PB Blaster and let it soak for a day or two. Then an impact wrench or a big breaker bar should do the trick.
Old 10-13-2010, 12:32 PM
Ek Forever y0!
Libertariat's Avatar
Agreed. Get a metal chisel (safety glasses) or an angle grinder and cut/grind the bolt off. Replace it with a bolt from the dealer and you're good to go.
That's exactly what the shop will do. Except with an air chisel and probably use different bolts.
Old 10-14-2010, 08:23 AM
akcapr's Avatar
yeah i bet i could get it out myself, but after doing my coilovers... and having to drill out the old bolts... id rather just pay a shop. i went through 15 hardmetal drill bits to drill through the bolts that connected my shock tower to the LCA, after they snapped when i took a breaker to it.
250,000 miles really rusts the **** out of those bolts
Old 10-14-2010, 08:27 AM
killahatch's Avatar
the performance shops around here charged 150
alphalanos's Avatar
Soak everything in PB a few times for several days before you do the job. Usually makes it alot easier
Old 10-14-2010, 04:19 PM
xlilriceboix's Avatar
wowwwww wth...lolz that kinda of high to charge for lca. u guy need to live down here in so cali n get 50 labor charge for lca lolz
Old 10-14-2010, 09:48 PM
AnthonyEKPRJ's Avatar
and then the cars stolen in a week. Damn socal thieves.
Old 10-15-2010, 01:35 AM
pm4nudes
chewyv's Avatar
*Find local HT member
*Pay HT member
*Save $50+
thi3v3z
06-18-2009 10:16 AM
AllMotoRex
11-27-2006 05:52 PM
iadubber
03-01-2003 03:16 PM
redteg1
08-17-2001 07:15 PM
AJTEG
06-21-2001 09:38 PM
Quick Reply: how much would a shop charge to install lower control arms?
