How to mix coolant/water ratio?
Old 05-30-2007, 06:18 PM
invisible's Avatar
Default How to mix coolant/water ratio?
how do you measure how much coolant and water to mix? probably going to run a little more water % than the usual 50/50 mix.
Old 05-30-2007, 06:27 PM
Mr.EM1_EK's Avatar
Default Re: How to mix coolant/water ratio? (cheesee)
just take an empty bottle and pour half coolant and half water. if you want more water then pour less coolant into bottle and add more water.
Old 05-30-2007, 06:30 PM
invisible's Avatar
Default Re: How to mix coolant/water ratio? (Mr.EM1_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK &raquo;</TD></TR><TR><TD CLASS="quote">just take an empty bottle and pour half coolant and half water. if you want more water then pour less coolant into bottle and add more water.</TD></TR></TABLE>
how much fluid does the car take?
Old 05-30-2007, 06:33 PM
Mr.EM1_EK's Avatar
not sure, just buy two bottles of coolant. you will be good.
Old 05-30-2007, 06:45 PM
Team RS2's Avatar
usally a bottle and a half i belive? this is bone dry
just keep filling it until it stops taking some it doesnt need to be precise
Old 05-30-2007, 06:50 PM
invisible's Avatar
Default Re: How to mix coolant/water ratio? (Team RS2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">usally a bottle and a half i belive? this is bone dry
just keep filling it until it stops taking some it doesnt need to be precise </TD></TR></TABLE>
im not using a premix
Old 05-30-2007, 06:59 PM
Mr.EM1_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesee &raquo;</TD></TR><TR><TD CLASS="quote">
im not using a premix </TD></TR></TABLE>
just mix it like i said, and fill up till it stops bubbling. put the cap on and let it run for a little. then check your level again
Old 05-30-2007, 07:00 PM
Team RS2's Avatar
neither do i
i have shevles of the stuff in my garage, and always keep an empty bottle for mixing
Old 05-30-2007, 07:21 PM
invisible's Avatar
oh. bottle has 3.78L and motor takes 4.7L, how much should i mix?
Old 05-30-2007, 07:25 PM
Mr.EM1_EK's Avatar
just mix that one bottle. it will equall to like two pre-mixed bottles.
Old 05-30-2007, 08:09 PM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK &raquo;</TD></TR><TR><TD CLASS="quote">just mix that one bottle. it will equall to like two pre-mixed bottles.</TD></TR></TABLE>
ok cool. ill just mix half of the bottle and half distilled water for now and keep the rest for later. what would that ration end up being?
Old 05-30-2007, 08:32 PM
Mr.EM1_EK's Avatar
that will be 50/50
Old 05-30-2007, 08:39 PM
invisible's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.EM1_EK &raquo;</TD></TR><TR><TD CLASS="quote">that will be 50/50</TD></TR></TABLE>
oh ok coo ill add/subtract when i do it then. thanks
Old 05-30-2007, 09:07 PM
Team RS2's Avatar
lmao are you joking? dude just mix the bottles lmao, **** if you're having this much troublew with it just pay the extra 5 bucks per bottle and buy 2
Old 05-30-2007, 09:13 PM
dtapia's Avatar
the honda long life coolant is pre mixed and designed for your car.
Old 05-30-2007, 09:14 PM
95ProjectEJ1's Avatar
And people are sitting here saying that buying premix is not worth it... for me, 10 dollars is worth saving all this time wondering how much water/coolant should be mixed. The thread before this one that the OP created was when i was at work over 7+ hours ago.
Do yourself a favor, work an half hour of OT this week and make up for the $10 you are going to spend on some 50/50 Prestone or Peak coolant.
Old 05-30-2007, 09:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">wtf man i want to see this guy post a topic on how to do an oil change lmfao, its not rocket science just mix half coolant and hlaf water in it, expletive man </TD></TR></TABLE>
Hahaha... Oil Change in the next 10mins FTW!!! Its not hard at all to mix coolant/water, but for those of us who are lazy and for those who can't measure, 50/50 is a good alternative. You will spend a total of 7 minutes between locating it in the auto store and going through the process to fill up your radiator and not 7 hours asking, which coolant is better and how the f*ck to mix it. Start a donation to buy a helms manual and a measure cup of some sorts
Old 05-30-2007, 09:31 PM
Go Tigers!
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 &raquo;</TD></TR><TR><TD CLASS="quote">lmao are you joking? dude just mix the bottles lmao, **** if you're having this much troublew with it just pay the extra 5 bucks per bottle and buy 2 </TD></TR></TABLE>
It's hard to imagine such a concept:
at one time, you had to learn how to mix antifreeze with water.
at one time, you had to learn how to do an oil change.
lol at you for being such a "SMART GUY"
-1%
nonvtec92
11
04-30-2008 02:45 PM
hondmywrld
05-09-2007 12:35 AM
NA_H22_Ej
06-17-2006 10:24 PM
2SlowDC
10-01-2005 08:32 PM
morepoop4u
12-16-2001 03:39 PM
Quick Reply: How to mix coolant/water ratio?
