need help removing the radio
Old 04-20-2002, 02:13 PM
sshaikh01's Avatar
Default need help removing the radio
Some dam thiefs tried to steal my cd player but they were unable to take it out, so they hammered it with screw driver, and took the face. Now i'm left no music, and a broken cd player.
I got a new cd player but i don't know how to take the whole thing out in a eg. I tried and ended up breaknig the ac unit. Can you somone please please post a step by step pics on where the scews are and stuff, how to do i take it out.
As you can see its a whole one piece thing. (this is not my car, i took it of the web to explain my point)
Old 04-20-2002, 03:16 PM
VtecDeMoN's Avatar
Default Re: need help removing the radio (sshaikh01)
Should just pull off. On another note you might want to take out a few other things and buy a can of flat black Krylon.
Brian
Old 04-20-2002, 03:20 PM
sshaikh01's Avatar
Default Re: need help removing the radio (VtecDeMoN)
I tried just pulling it off, thats how i broke the ac unit.
so, i don't want to take any chances.
I'm sure it pretty easy.
but i just can't find the screws or clips which are holding it in place.
Old 04-20-2002, 03:36 PM
C1V1C's Avatar
what kind of deck is it? theres usually 2 keys that slide in the sides to push down tabs which will release the deck. The keys should have come with the deck, otherwise you'll have to find a couple of small screw drivers to push the tabs with.
Or ask the guys at the shop where you bought the deck if they can just pop out the deck, I got them to do that for me cause I didn't have the keys.
Old 04-20-2002, 03:39 PM
sshaikh01's Avatar
Default Re: need help removing the radio (C1V1C)
i don't have the keys, and i don't know who put the deck in.
my best bet is to take that panel out, but i don't know how to ??
Old 04-20-2002, 03:41 PM
C1V1C's Avatar
you don't need to take the panel out, you just have to find the tabs to release the deck from the sleeve, take it to a shop if you can't figure it out, otherwise you might do some damage.
Old 04-20-2002, 03:49 PM
Malachi's Avatar
pieces of coat hanget make for nice replacements for the keys.
Old 04-20-2002, 03:51 PM
sshaikh01's Avatar
Default Re: need help removing the radio (Malachi)
i'm sorry but i don't understand what do you guys mean by this.
Ok, lets say i get a coat hanger, so what would i do than, how would i use it to
get the deck out ????
Old 04-20-2002, 04:39 PM
mps9506's Avatar
should be two flat slots on each side of the deck, probably about 1/2 inch long on each side, or about large enough to fit a house key into. Taking that entire plastic thing off doesn't work too well because it's held in there by a billion little screws if I recall correctly.
Just take two long car keys and stick it in each side, it will cause the cd unit to seperate from the din cage that is in the dash and you can carefully pull the radio out without it dropping back down. If you know anyone that works at a car stereo shop they should pull it out for free.
Old 04-20-2002, 04:42 PM
sshaikh01's Avatar
Default Re: need help removing the radio (mps9506)
i did not notice any small holes on the sides.
Old 04-20-2002, 04:45 PM
Malachi's Avatar
its right down the middle of both sides of the cd player. stick something thin in there about 3 inches or so and pull the cd player out.
Old 04-20-2002, 04:47 PM
sshaikh01's Avatar
I should look for it on the bottom of the cd player unit right.
cool.
I'll go and try that.
Thanks for all of your help.
Old 04-20-2002, 04:51 PM
Malachi's Avatar
on the left and right side of the cd player, in the middle. make sure you removed the plasic trim.
Old 04-20-2002, 04:56 PM
Malachi's Avatar
look where the circles are, pull of the plastic trim that goes around the faceplate.
Old 04-20-2002, 04:57 PM
JaeOne3345's Avatar
i just did this,,remove the console part with the ash tray and lighter and **** first. then look up u will see some screws for the radio..remove..pull out. i dunno if this helps but this is for when i installed a 99si unit in my 93
Old 04-20-2002, 04:59 PM
sshaikh01's Avatar
I think i got what you're talking about.
Thanks Malachi
you were a great help.
I will try that at my ealiest convience.
pnoi_boi68
07-21-2009 04:11 AM
jonathan13
Audio / Security / Video
12-30-2007 11:15 AM
fito22
Honda Civic (2001 - 2005)
01-17-2007 05:12 PM
taralj
09-04-2004 06:40 AM
Race Egr
12-08-2003 11:59 PM
Quick Reply: need help removing the radio
