how to fix 5 codes (really only 3)
Old 04-21-2005, 03:26 PM
jazz1320's Avatar
Default how to fix 5 codes (really only 3)
1*P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction code 1
2*P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction code 2
3*P1337 Engine Speed (RPM) Fluctuation Sensor No Signal
4*P1508 Idle Air Control Valve (IACV) Circuit Malfunction
p0450 code 14
5*p0450????
1&2- i pretty i can easliy fix this but getting 2 new sensors and a cat
3- no clue at all
4- i have no clue bc my idle is great 500-1000rpm
5- cant find it
any tips or pointers would be great!
Old 04-21-2005, 03:29 PM
jazz1320's Avatar
Default Re: how to fix 5 codes (jazz1320)
bump
Old 04-21-2005, 04:06 PM
hookedonvtec's Avatar
you fix the code 4 by just cleanin the idle control valve. thats ll i had to do to mine
Old 04-21-2005, 04:10 PM
jazz1320's Avatar
Default Re: how to fix 5 codes (hookedonvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hookedonvtec &raquo;</TD></TR><TR><TD CLASS="quote">you fix the code 4 by just cleanin the idle control valve. thats ll i had to do to mine</TD></TR></TABLE> with parts cleaner?
Old 04-21-2005, 05:17 PM
TurboEM1's Avatar
for #4 the IACV clean it out with carb cleaner. same thing happened to me and it worked great. Also it is usually located on the back of the intake manifold and has 2 or 3 bolts and to coolant lines going to it.
reed857
29
07-26-2009 10:57 AM
crusto2k3
12-01-2008 02:14 PM
slacks
09-20-2007 07:24 PM
Pyronus
08-13-2006 12:28 PM
trick_db
08-01-2006 09:27 PM
Quick Reply: how to fix 5 codes (really only 3)
