Honda Type 2 Coolant the blue stuff
Old 09-15-2005, 09:23 PM
silvercivicsir's Avatar
Default Honda Type 2 Coolant the blue stuff
Can you mix the type 2 coolant, (blue kind ) with the regular green stuff ? I'm planning on doing a rad drain and refill..
Old 09-15-2005, 10:19 PM
turtle-eg's Avatar
Default Re: Honda Type 2 Coolant the blue stuff (silvercivicsir)
No... the blue stuff is organic with no phosfates(spelling?) which the green coolant contains.
If you wanna use the blue one, completely flush out the cooling system and then add the new coolant.
Old 09-15-2005, 11:13 PM
Echo7847's Avatar
Default Re: Honda Type 2 Coolant the blue stuff (turtle-eg)
The Honda green and blue coolant will mix fine, they almost the exact same thing just a different color to distinguish b/w the type 1 and type 2. If your using some other noname stuff then flush it out.
More than likely it will be fine.
Old 09-16-2005, 03:33 AM
Banned
CardDealer's Avatar
Default Re: Honda Type 2 Coolant the blue stuff (Echo7847)
Modified by CardDealer at 4:33 PM 11/16/2006
Old 09-16-2005, 09:43 PM
Default Re: Honda Type 2 Coolant the blue stuff (schlit)
thanks for the reply.. did the coolant change today and everything seems to be ok.
Old 09-16-2005, 09:49 PM
Jago's Avatar
I work at a dealer we mix it all the time. There is no diference between the two
one is just blue thats all. I think they did it so they could tell if the vehicle had been serviced at another dealer
Old 09-17-2005, 02:50 AM
Lude@Heart's Avatar
so yer sayen that if honda does a flush the coolant will be blue?
Old 09-17-2005, 05:38 AM
nsxmatt's Avatar
Default Re: (Lude@Heart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lude@Heart &raquo;</TD></TR><TR><TD CLASS="quote">so yer sayen that if honda does a flush the coolant will be blue?</TD></TR></TABLE>
Yes, well if you had green before it will be a aqua color since it will still have some green in the system.
Old 09-17-2005, 07:43 AM
Chiovnidca's Avatar
If they use the Honda type 2 antifreeze. Some dealers use cheaper stuff.
Old 09-18-2005, 11:16 AM
Jago's Avatar
Default Re: (Chiovnidca)
all we get is the new stuff they don't sell the old coolant anymore
Old 09-18-2005, 11:20 AM
Bcuz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvercivicsir &raquo;</TD></TR><TR><TD CLASS="quote">Can you mix the type 2 coolant, (blue kind ) with the regular green stuff ? I'm planning on doing a rad drain and refill..
Yes you can, think of everytime someone changes there coolant to the new stuff, how many people actually think of the dumping the old coolant out of the resevior, and replacing with new coolant.
Now, I do it cause I'm thorough like that.
Paprika
06-13-2022 05:32 PM
wangan
10-06-2014 06:19 PM
OldMrAccord
11-24-2010 07:40 PM
blueh
Honda Civic (2006 - 2015)
10-29-2009 04:22 AM
return_2020
Honda Civic (2001 - 2005)
08-19-2006 08:53 AM
Quick Reply: Honda Type 2 Coolant the blue stuff
