HELP! Sparkplug wire pops out! Oil on spark plug!
Old 08-18-2005, 11:45 PM
JDM Approved's Avatar
Default HELP! Sparkplug wire pops out! Oil on spark plug!
I am running fairly new Bosch spark plugs and fairly new NGK blue wires. on my third cylinder, my spark plug wire keeps popping off every minute or so. when i pull out my spark plug wire, there is oil all over it.
what can i do to solve these problems on the third cylinder?
1) sparkplug wire popping out
2) oil on sparkplug wire
thanks!
Old 08-18-2005, 11:49 PM
spankey167's Avatar
Default Re: HELP! Sparkplug wire pops out! Oil on spark plug! (JDM Approved)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Approved &raquo;</TD></TR><TR><TD CLASS="quote">I am running fairly new Bosch spark plugs and fairly new NGK blue wires. on my third cylinder, my spark plug wire keeps popping off every minute or so. when i pull out my spark plug wire, there is oil all over it.
thanks! </TD></TR></TABLE>
Where does te spark plug wire pop out from? Off the distributor or on the head?
If your spark plugs are covered in oil, you will need new spark plug gasket seals and you might as well change your valve cover gasket seal
Old 08-18-2005, 11:53 PM
Phase2's Avatar
Default Re: HELP! Sparkplug wire pops out! Oil on spark plug! (xSpanksx)
it pops off of the valve cover, right?
Old 08-18-2005, 11:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phase2 &raquo;</TD></TR><TR><TD CLASS="quote">it pops off of the valve cover, right?</TD></TR></TABLE>
yessir!
Old 08-19-2005, 12:13 AM
JDMlyfestyle's Avatar
u sure that ur spark plugs are on tight? cause my friend had a semi loose spark plug and some of the pressure from the cylinder pushed the spark plug off.
Old 08-19-2005, 03:05 PM
Phase2's Avatar
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">u sure that ur spark plugs are on tight? cause my friend had a semi loose spark plug and some of the pressure from the cylinder pushed the spark plug off.</TD></TR></TABLE>
Old 08-19-2005, 05:01 PM
rac53041's Avatar
same thing happened to me check if sparkplugs are tight
Old 08-19-2005, 05:21 PM
rabius's Avatar
&lt;_&lt;
&gt;_&gt;
dont use bosch
NGK V-Power FOR THE WIN!!
&lt;/opinion&gt;
Old 08-19-2005, 06:05 PM
AdamQ3B85's Avatar
If the spark plug has oil on it then that might be why the wire is popping off... Replace the spark plug seal on the valve cover and get new NGK plugs...
Old 08-19-2005, 06:50 PM
dmxsoulja3's Avatar
Default Re: HELP! Sparkplug wire pops out! Oil on spark plug! (AdamQ3B85)
OEM valve cover gasket set and new set of spark plugs...done
Old 08-20-2005, 02:55 PM
Default Re: HELP! Sparkplug wire pops out! Oil on spark plug! (dmxsoulja3)
i'm about to get off my *** and check to see if the spark plug is loose or not. in the mean time, any one else have any input?
dabeast111
06-05-2011 08:43 PM
imroadk1ll
03-23-2010 04:21 PM
vsmftw98
08-04-2009 02:14 PM
hondaeg8
11
07-29-2004 10:37 PM
slowd16z6
03-13-2004 07:12 PM
Quick Reply: HELP! Sparkplug wire pops out! Oil on spark plug!
