Help please eg8 dohc zc - electrical problems
I have a 1995 eg8 with a obd1 dohc zc and I drove my car Saturday night and went to crank it Monday and it was completely dead no lights or anything the 80a battery fuse was blowin and the p75 ecu had a burnt spot on it so I replaced the fuse and put a p06 in I had and all that happend was the guages light up the brights, brake, and battery light stay on with the ignition off and no headlights on or blinkers ect the car just turns over nothing else I'm lost please help
Re: Help please eg8 dohc zc
Before you get shitty, you should read the FAQs sticky. There's a no-start diagnostic walk-through there. While you're doing that, read the rules - your thread should have an informative title. "Help please" isn't informative.
Seagull Management
Check the big white wire coming off the alternator, see if it's shorting against the bracket under the intake manifold (or anywhere else for that matter) If you're blowing the 80A battery fuse and the battery, cel, etc stay on with the ignition off you have some serious wiring issues.
94eg8 thank you I will check that I almost have the dash out I also noticed that the b1(it's brown) wire on the ecu is wired into another wire I have a picture but idk how to post it
Jbpnoman your offering no help just your smartass responces
I will just be taking it to the shop I feel as if I'm talking to a bunch of 13 year old smartasses
The Grumpiest
Best thing you could do since you don't seem to even be capable of posting pictures or correct wiring issues that are right in front of you. Don't see that you actually did even the simplest of things like checking fuses. And it seems your wiring is hacked to **** that you're having issues YET no back story or any details about it. Maybe you need to get your hands on a field service manual and accompanying wiring guides.
Uh. Yeah. He knows you have wiring issues too.
You want people to help but you cannot even help yourself or help people to help you.
Ok after pulling the dash the dome light shorted out and basicly shorted out the entire cabin harness and burnt most of it up. My past question is dose this entire harness end in plugs so I can get a new one and just plug it in
Re: Help please eg8 dohc zc - electrical problems
I was hoping it dident but oh we'll it looks like theirs 3 sets of two wires that run to the driver side also the only ones I can see that are not in that plastic loom are solid blue and white
But the harness is from a 93 I think it dident have an airbag on the dash?? Also had power mirrors door locks and windows and was an auto please tell me I can still make this work.
