help key stuck in ignition
Help the I went to start my automatic 96' Civic and the key is stuck in the ignition the key will not come out but it will not turn all the way to start the car. The steering wheel has lots of play, and the park light is lit. Any suggestions. Would prefer not to have to get it towed to dealership...
Re: help key stuck in ignition (lazie)
the key will not come out nor will it turn all the way to start the car we have been tring to jiggle the key and play with it for 3 hours and no luck
Re: help key stuck in ignition (93egsedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan »</TD></TR><TR><TD CLASS="quote">so you cant pull it out of the ignition, how hard are u pulling it?</TD></TR></TABLE>
you pull to hard you'll break the key
Re: help key stuck in ignition (Quick Hatch)
you may have a short somewhere. I'm not sure if the interlock solenoid just makes it so you cant start in any other gear and cant take it out of park unless your foot is on the brake OR it might also prevent removing the key. might wanna check into that
Re: (True Pyroman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by True Pyroman »</TD></TR><TR><TD CLASS="quote">try jiggling the steering wheel while moving the key, that's happened to mine before but all it takes is to wiggle the steering wheel.</TD></TR></TABLE>
Hazem
15
12-16-2004 01:54 PM
