HELP..bypassed coolant from heatercore...turned on car and it revs up to 4k ?!?!?
Old 06-28-2010, 04:36 PM
jxhxb's Avatar
Default HELP..bypassed coolant from heatercore...turned on car and it revs up to 4k ?!?!?
so i foung out something was wrong with my heater core and i have coolant all over my floor inside my car...so i was told to bypass the coolant for now...i just did that now and i filled it up with coolant..( dont know if i was supposed to do it in a certain way..tried squeezing coolant hoses to burp it)...and then i turn on the car and it revs up to like 4k rpms so i turn it off and it makes a sputtering noise while it turns off...
do you think theres an airbubble in the coolant?? i opened the radiator cap and the coolant was white/bubbly on top....
Old 06-28-2010, 04:48 PM
Former User's Avatar
Default Re: HELP..bypassed coolant from heatercore...turned on car and it revs up to 4k ?!?!?
Bleed the cooling system.
Old 06-28-2010, 04:58 PM
jxhxb's Avatar
Noob here... How do I do that?!!
Old 06-28-2010, 05:05 PM
What engine?
Old 06-28-2010, 05:09 PM
jxhxb's Avatar
Jdm d15b same basically as a d16z6
Old 06-28-2010, 05:16 PM
Bleeding the cooling system:
(may take 20-30 minutes)
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
GeneBEllis
05-10-2013 05:44 PM
Fuzbal
Honda Civic (2001 - 2005)
10-20-2012 04:19 PM
95dc2teg
09-24-2007 08:15 PM
drdavidge
12-15-2002 05:58 PM
Pat
01-27-2002 05:12 PM
Quick Reply: HELP..bypassed coolant from heatercore...turned on car and it revs up to 4k ?!?!?
