HELP BATTERY INSTALLED BACKWARDS, turned battery right way no start, changed fuse.
Old 08-11-2012, 05:05 PM
EusebioSam19's Avatar
Default HELP BATTERY INSTALLED BACKWARDS, turned battery right way no start, changed fuse.
My brother accidentally installed his battery backwards
I came over fixed turned it right ways
80a fuse popped & I changed it, no under dash fuses are popped.
Any ideas? His cars stuck outside his gf's house were tryna get it movin today
Old 08-11-2012, 06:33 PM
Josueneta's Avatar
Default Re: HELP BATTERY INSTALLED BACKWARDS, turned battery right way no start, changed fuse
have you checked the fuse for the ECU
and dose it get power?
does it turn over ?
lights work ?
Old 08-11-2012, 07:02 PM
Lights work, Is ecu fuse under hood or under steering wheel?
Old 08-12-2012, 01:19 PM
yabuddie's Avatar
i would look at all fuses and relays to see if you see any burn marks as ive seen this happen before and there is no way of testing a relay but we did find an obviously burned one replaced it and worked
Old 08-12-2012, 01:29 PM
Former User's Avatar
Do both bolts of the 80A fuse have battery voltage to body ground?
freewealthana
06-22-2017 11:07 PM
preluderacer88
07-29-2008 12:29 PM
Mychal71
09-10-2006 02:01 PM
FastHatch90
04-03-2006 07:47 PM
Quick Reply: HELP BATTERY INSTALLED BACKWARDS, turned battery right way no start, changed fuse.
