rear brakes to disk
Old 12-22-2009, 12:14 AM
curioso's Avatar
Default rear brakes to disk
ok guys i dont know if im int he right section but here is the deal
and i try to search and nothing came up or maybe i didnt search good enough
well i have a 98 ex coupe with drums
and i have an integra for parts and i want to put the rear disc from the integra into my coupe
how hard is it and will it bolt up thanks guys
Old 12-22-2009, 12:39 AM
civic_r87111's Avatar
Default Re: rear brakes to disk
It's a 2-3 hour job but not really that hard and it will bolt right up, u should find more info on it in the FAQ section in the thread.
Old 12-22-2009, 05:56 AM
300whpej's Avatar
the entire trailing arm should bolt up with little to no issues. i plan on tackling this myself soon, but shouldnt take too long if you have the proper tools. the brake section should give you a little more information on the information youre looking for.
Old 12-22-2009, 06:16 AM
92ehatch's Avatar
it is a direct bolt on.
the hardest part is the e brake cables, which isnt that hard at all
its easier to have a second person to help lift them tho. they arent light when you are laying under a car, or crouched next to it
Old 12-22-2009, 03:28 PM
curioso's Avatar
ok guys thanks ill be doing this swap within the next 2 weeks ll take some pics of the swap
Old 01-16-2010, 01:33 PM
curioso's Avatar
so the e brake cables from the integra would work on the ek right guys?????
Old 01-16-2010, 01:44 PM
velisma's Avatar
I think the integra brake cables should work on an EK... I did this swap in my 94 EG hatch and I used the E-brake cables from a 96 Integra LS w/ no problems at all. If nothing else, you could use the E-brake cables from a 99-00 Civic Si. I know those will definitely fit.
Please tell me you got the rear brake hoses w/ the swap too. If not, you have to buy the brake hoses for the integra
Old 01-16-2010, 01:45 PM
curioso's Avatar
oh ok well hopefullythe ones from the integra fit cuz im getting everything from that car so
i dont want to be looking for the si ebrake cables
Old 01-16-2010, 01:54 PM
velisma's Avatar
Don't worry, everything should go very smoothly for you... You know the old saying... if you can play with legos, you can mess with a Honda... lol!
oh almost forgot... does the rear disk set you're getting have ABS?
Old 01-16-2010, 08:56 PM
Doesn't all integras have ABS?? 93+ anyway
CHAVOB18
05-05-2015 01:01 PM
ShortbusEK
10
08-24-2009 02:19 PM
JDMkidGSR
12-10-2004 10:38 PM
hair_rice
11
01-27-2004 01:49 AM
Quick Reply: rear brakes to disk
