h4 to h4h
Old 04-18-2004, 09:44 PM
OoHiTzToMMy's Avatar
Default h4 to h4h
is there a way to make h4 bulbs fit into a jdm h4h headlights
Old 04-19-2004, 10:17 AM
built562's Avatar
Default Re: h4 to h4h (OoHiTzToMMy)
no, in short no, there have been people that say they trim them toi make them fit but i have yet to see proof.
altough there was a guy who made HID from another car fit by jdm weldding the bulbs in the headlights
Old 04-19-2004, 10:26 AM
dwnthehatch's Avatar
Default Re: h4 to h4h (akumaracer)
It will require alot of precise cutting.
-------------H4-----------------------------------------H4H
Old 05-07-2004, 09:03 PM
B18C GSR CIVIC's Avatar
Default Re: h4 to h4h (dwnthehatch)
Ive done it many times with ease! You just have to bend that **** with plyers. I have piaa h4's in my jdm jams!
Old 05-07-2004, 09:27 PM
H-T Poker champion
Hatchy-Ownzjo0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">
Just by looking at this picture I can tell you how to do it.. It would take all of 2 minutes to do as well..
Notice that the base of the 2 bulbs is the same. the only difference is the outer part with the tabs. Well, you see where the outer part with tabs is "welded" to the base.(just look for the spots, you can't miss them, but you can't see them in the pic because you have to look from above). There are prolly 3 or 4 if i remember correctly. Now, get some wire cutters or any other sharp cutting tool and cut those "welds" and the outer part will come off. Now all you have to do is put the h4h outer part onto the H4 base and secure it by JB weld or some other method and BAM.. there you go.
Old 05-07-2004, 10:51 PM
stockegsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoHiTzToMMy &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to make h4 bulbs fit into a jdm h4h headlights</TD></TR></TABLE>
i did it, i used a dremel, its not worth it though, the light beam pattern is too high, its like you have your high beams when you turn on the headlight, then when you high highbeams the light beam is too low, just get a pair at jdmhondapart.com
Modified by stockegsix at 9:59 AM 5/8/2004
Old 05-07-2004, 11:41 PM
EG2 SiR's Avatar
Default Re: h4 to h4h (stockegsix)
Curious as to why you would want to do this? cost of h4h? JHPUSA.COM sells them. and you can find raybrigs on ebay a lot.
Old 05-08-2004, 10:04 AM
VX_SOHC's Avatar
Default Re: h4 to h4h (EG2 SiR)
true that you can get em off ebay and other places, but when your cheap and cant justify dropping that much $ on a set of bulbs this is what you can do.
Spectrum24x
06-29-2005 01:10 PM
JDMGSRCRX
04-05-2005 05:46 AM
grenthang
13
11-25-2004 11:32 PM
wisjdmhonda
03-06-2004 10:48 AM
slowerthanu
09-18-2002 04:22 PM
Quick Reply: h4 to h4h
