d16z6 distributor on NON-vtec motor?
Old 09-20-2011, 10:49 AM
JJDd16z6's Avatar
Default d16z6 distributor on NON-vtec motor?
I had a d16z6 in my EG civic and it blew on me, put a rod thru the oil pan. I bought a JDM ZC (1.6 non-vtec) and am moving along with the swap quite well. I was just wondering if the d16z6 VTEC distributor will work with the NON-VTEC motor?? The bolts line up perfectly and the key on the distributor fits into the slot on the cam in the motor perfectly too. I just need to know if the car will run smoothly with the d16z6 distributor installed?? please help!?!
Old 09-20-2011, 10:50 AM
dem0nk1d's Avatar
Default Re: d16z6 distributor on NON-vtec motor?
it should be fine as long as you dial in the timing. bolt it on, and adjust timing... that's it...
Old 09-20-2011, 11:02 AM
PHANTOM MENACE
24TEN's Avatar
To my understanding the VTEC distributors have the same sensors but one of them is 180degrees off. If you get a check engine light or it runs funny, this is probably the cause.
NOTE: The Z6/Z1 distributor flange is unique, if the old distributor mounts perfectly to the non-VTEC head you probably had a Y8 head on your Z6 block.
EDIT-Read this, then decide http://www.d-series.org/forums/gener...th-busted.html
Old 09-20-2011, 11:17 AM
bunkrd you's Avatar
if you need a non vtec dizzy for the motor message me i got one for 30 shipped
Old 09-21-2011, 01:44 PM
JJDd16z6's Avatar
24TEN your right I went to my garage before getting any replies. I got the dizzy into the head but like you said the 3 arm flange didnt line up with the 3 bolt spot on the head . Any advice on what dizzy I need to get would be helpful. (haven't read the link in ur reply 24TEN, so if the answer is in there thanks in advance)
YangFlavor
04-29-2019 01:53 PM
Kris's turbo
04-24-2012 11:10 AM
dmcclain
08-10-2006 05:21 AM
-[95cxhatch]-
12-16-2003 06:46 PM
HarryB
08-13-2002 09:13 AM
Quick Reply: d16z6 distributor on NON-vtec motor?
