fuel gauge wiring with pics?
Old 08-30-2014, 09:45 AM
Civic Racer X 7's Avatar
Default fuel gauge wiring with pics?
Ok so I have a stripped race car
and I need a way to be able to tell the amount of fuel in the tank
I went to the junkyard and pulled a stock fuel gauge
it has 3 screws on the back of it for electrical connection
I looked at the fuel tank and there are 2 plugs
one is the fuel pump controls and wiring
and there is a 2nd plug that has 2 wires that the previous owner snipped off
Im sure there is a simple connection I can make to have a reading on my fuel tank
anyone familiar with whats what and what goes where?
Old 08-31-2014, 07:19 AM
Default Re: fuel gauge wiring?
Anyone know the wiring
Old 08-31-2014, 10:49 AM
Hysterically Calm
TomCat39's Avatar
Ya know, for all we know your race car is a Ford Fairlane with a Chevy small block in it and a Dodge rear end.
Rather impossible to isolate wiring on a random unspecified car.
Old 08-31-2014, 08:31 PM
Lol sorry
94 hatch
Old 08-31-2014, 08:52 PM
Hysterically Calm
TomCat39's Avatar
Originally Posted by Civic Racer X 7
Lol sorry
94 hatch
Okay now we have a 94 hatch with a chevy small block and the dodge rear end.....
Come on man, you say race car so how can we magically know what motor or mods are swapped in for the track. And if you say stock, we still don't know what trim level so it could be 1 of 4 engines for the USDM 92-95 hatch.
How do we know you don't have a walbro fuel pump to power 800CC injectors on your turbo K20 swap.
All car information is very important when asking for technical help. Anything less doesn't get you any reasonable answers.
Old 08-31-2014, 09:02 PM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
as long as the gauge and sender match, doesnt matter whats under the hood
Old 08-31-2014, 09:09 PM
Hysterically Calm
TomCat39's Avatar
Would the sender stay the same if there was an aftermarket fuel pump put in? I assumed the sender was incorporated into the pump. I haven't actually looked at the pump and sender setup in my car yet. My focus has been main in the engine compartment.
Also just making the point of the rules for the model specific tech forum, all car information is supposed to be present.
Old 08-31-2014, 09:46 PM
I dont think the sender itself would change, why arent you running a cell, and just run an aftermarket sender and gauge?
Old 09-01-2014, 11:47 AM
Hysterically Calm
TomCat39's Avatar
Not my car or issue. OP hasn't provided whether its a stock setup, stock guages, trim level of car, or if it's not stock, what the mods are.
If it's stock, then the brown 2 pin connector C564 with Yellow/Green wire and a Black wire (which runs to ground G551) is your fuel pump.
The brown 3 pin connector C563 with what appears to be only 2 live wires, a Yellow/White wire and a Black/White wire (that runs to ground G551) is your fuel gauge sending unit. The Yellow/White wire traces to connector C502 and continues up to connector C511 where it looks like it plugs into the gauge assembly.
The fuel guage readings in the manual shows E = to 105-110 ohms of resistance while 1/2 tank = 25.6-39.5 ohms and a full tank shows a mere 2-5 ohms of resistance.
Even though the C563 is a 3 pin plug, I only see two active wires in the manual.
Old 09-01-2014, 01:54 PM
OP you will have to search, but I have seen some aftermarket gauges that can be programmed to work off of any sender, providing you know the OHM range
Old 09-07-2014, 01:05 PM
Default Fuel gauge wiring question with pics
Ok so I'm in desperate need of a fuel gauge on my car car
1994 civic hatch
Here is a pic of the 3 connections on the rear of the gauge
And also a pic of various wires on the sending unit
What wires connect to where in order for this gauge to operate?
Is there a diagram I need to reference?
Old 09-07-2014, 01:07 PM
Default Re: Fuel gauge wiring question with pics
The fuel pump is wired but there are 2 wires not used
That I suspect are for the fuel gauge
Old 09-08-2014, 11:28 AM
Anyone know where to find this information ?
Old 09-08-2014, 01:25 PM
firehawk618's Avatar
Yes, when I get home I will post related wiring diagrams.
You do not wire the sending unit directly to the gauge. The wiring goes to the plug behind the cluster then via printed circuit to the gauge itself.
Old 09-08-2014, 03:28 PM
In my race car in don't have any of that
I was gonna wire it direct to the gauge because
I can't tell how much fuel in have and actually ran out of gas on the track
Doh!
Old 09-09-2014, 03:23 AM
Default Re: fuel gauge wiring with pics?
Getting some good information so far
Seems there would be a schematic that tells what each of those 3 connections on the rear of the gauge are
Old 09-09-2014, 06:11 PM
Global Moderator
tech8's Avatar
Here is a description of how the fuel gauge works:
The fuel gauge has two intersecting coils wound around a permanent magnet rotor. Voltage applied to the coils, through Under—dash fuse no. 15 via Yellow wire, generates a magnetic field. The magnetic field, controlled by the fuel gauge sending unit, causes the rotor to rotate and the gauge needle to move. As the resistance in the sending unit varies, current through the gauge coils changes. The gauge needle moves toward the coil with the strongest magnetic field.
Fuel Gauge Readings:
E – 105-110 ohms
½ – 25.5-39.5 ohms
F – 2-5 ohms
This is what it looks like to me.
Old 09-09-2014, 06:18 PM
Here's your diagrams.
Fuel gauge "from cluster" goes to pin B1 which is Yellow/White to the sending unit. The Black/White wire on the sending unit goes to ground.
Old 07-02-2017, 07:43 AM
Aditya Ryan's Avatar
Thanks for this old topic, i managed to diagnose and solved my old civic 1994 from your cable diagram. I connected the broken spool wire behind the fuel indicator. May be broken by turning the bolt too tight. Sorry for my bad translate, maybe. Hehe im indonesian.
Linked
05-31-2009 07:00 PM
jdub20tx
02-09-2007 07:55 PM
b.d.racing
04-12-2006 08:09 PM
uszcrx
08-21-2003 01:00 AM
wannakno
06-27-2003 08:20 AM
Quick Reply: fuel gauge wiring with pics?
