frozen axle nut
Old 01-05-2008, 07:17 PM
juzthewy's Avatar
Default frozen axle nut
My axle nuts dont wanna budge, is there another way to remove the axles so that i can take out my motor/tranny? TIA
Old 01-05-2008, 07:24 PM
juzthewy's Avatar
Default Re: frozen axle nut (juzthewy)
bump
Old 01-05-2008, 07:26 PM
Colby71's Avatar
There might be a way but it would be so much more a pain in the ***. Get a long braker bar. have the tiers on without caps so you can get to the nut put it on the ground put it in gear have some one hold the brake while another person jumps on the braker bar.
Old 01-05-2008, 07:27 PM
random chaos 85's Avatar
heat up the nut a little and hit it with the impact gun works every time
Old 01-05-2008, 07:33 PM
duefuss's Avatar
well the little advice i have on this is even if you dont have an impact gun its nice to have a set of impact sockets for this and a 4 foot breaker bar........ or find some one with a compressor and an impact gun.....
Old 01-05-2008, 07:35 PM
97Ej6mike's Avatar
More man power... also try using PB blaster or WD40 to loosen up the nut.
Old 01-05-2008, 07:45 PM
Colby71's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">More man power... also try using PB blaster or WD40 to loosen up the nut.</TD></TR></TABLE>
WD40 is junk for this. It is a lube not a thred penatrating oil like PB blaster.
Old 01-05-2008, 07:47 PM
97Ej6mike's Avatar
Default Re: (Colby71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colby71 &raquo;</TD></TR><TR><TD CLASS="quote">
WD40 is junk for this. It is a lube not a thred penatrating oil like PB blaster.</TD></TR></TABLE>
PB has def come thru moreso than WD, but whichever of the 2 is available to you, use it. Also, a torch may help the situation. Friend had a stuck axle once, and we used a torch to heat it up a little, and it broke free. Be careful around the brakelines tho.
Old 01-05-2008, 07:50 PM
iBear's Avatar
Heat it up and use a breaker bar.
Easier said than done though. I've been through the same thing. GL.
Old 01-05-2008, 07:52 PM
97Ej6mike's Avatar
Soak with PB, let it sit for a minute, and then heat it up for about 30 seconds, and repeat this, with intermittent try's at taking the nut off. It should come off soon.
Old 01-05-2008, 08:37 PM
CapnKrunch's Avatar
WD40/PB Blaster and Impact Gun
Old 01-05-2008, 08:39 PM
luvmihatch's Avatar
Default Re: (CapnKrunch)
i had this same issue way back when so what i did was spray alot of pb blaster let ti sit then i hit it with the impact gun but clock wise. some times this helps break the seal then loosen it up... sounds dumb but it works
Old 01-05-2008, 08:52 PM
Johnny Ricer's Avatar
Default Re: (luvmihatch)
If you dont have a 4' breaker bar take a 1 or 2 foot one put it on and slide about three feet of steel piping around the breaker bar stand on it and bounce up and down. Also try heating the nut and spraying it with a penatrating oil as well it should come off eventually, I let mine soak in the oil 3 days spraying them once in the morning once at night and on the third day I was able to heat it up and break it loose using a 1' breaker bar.
Old 01-05-2008, 09:13 PM
juzthewy's Avatar
Default Re: (Johnny Ricer)
thanks for the replies fellas. i guess pb blaster + heat + brute force is the way to go
my boy told me, worse case scenario, cut the boot on the axle behind the hub and rip out the axle (i do have new axles) anyone know of this method?
Old 01-05-2008, 09:15 PM
EG6 Poe's Avatar
I second the impact gun..... It gets the job done so much faster and easier!!
Old 01-05-2008, 10:01 PM
Default Re: (juzthewy)
Ripping the boot and pulling it out is'nt going to work without breaking the axle hub nut loose one way or another. It holds the axle onto the hub and can't be removed until the nut is so that isnt a great idea.
Old 01-05-2008, 10:22 PM
Midori Green's Avatar
drive off a cliff punk!!
Old 01-05-2008, 10:26 PM
JDM EJ2's Avatar
Spray some Zep45 on that SOB then hit it with the breaker bar. Ur in for an extra hour of work if you break it tho so good luck with that
Old 01-05-2008, 10:36 PM
VRD^sam's Avatar
Default Re: frozen axle nut (JDM EJ2)
I had the same problem on my car, went out to sears picked up myself a craftsman 500ft lb impact gun, never been so easy
Old 01-05-2008, 10:52 PM
strsi's Avatar
Default Re: frozen axle nut (VRD^sam)
larger breaker bar or biggest rachet you have with a very large piece of steel tube fit over it. Leverage&gt;strength
Old 01-05-2008, 11:04 PM
Hondacivic90ed's Avatar
I would do it the same way I do it at the junkyard. Just pull the lower balljoints on both sides and pull the axles out of the transmission, you should have enough room to slide the thing out. I've never had to remove the axle nuts to get the engine or trans out if I couldn't get the axle nuts to budge. I don't have access to air tools at the junkyard, otherwise I would use an impact gun to zip it off.
Old 01-05-2008, 11:06 PM
CruiserDan's Avatar
Default Re: frozen axle nut (strsi)
penetrating oil and heat are your friend with this kinda problem. like said before tighten it then loosen it. also hold tension on the breaker bar and hit the end with a hammer the vibrations tend to help things break loose. if all else fails. oxy. acetylene torch, blast that thing off.
Old 01-05-2008, 11:28 PM
ejcoupe95's Avatar
i had the same prob and a 900ftlbs impact wouldnt take it off but i had a friend that workes at a dealership and he used a 1600ftlbs impact and it was no problem.
Old 01-06-2008, 04:38 AM
StorminMatt's Avatar
Default Re: (ejcoupe95)
You might also look into getting a .75 inch breaker bar and socket. I find that anytime I use .5 inch stuff on a frozen nut with a cheater, I always end up breaking something. Usually, I end up shearing the drive from the ratchet/breaker bar.
On the other hand, if you are pressed for time with a swap, the swap does not require different axles, and you don't want to mess with this right away, you can simply break the lower balljoint. When you do this, you should be able to move te steering kunckle away enough to be able to pull the axles from the transmission.
Old 01-06-2008, 05:08 AM
Rotary Lift Specialist
Cain Marko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Soak with PB, let it sit for a minute, and then heat it up for about 30 seconds, and repeat this, with intermittent try's at taking the nut off. It should come off soon.</TD></TR></TABLE>
No no no, not intermittent. When you go to hit that nut, go at it until the damn thing comes off. Once you hit it with PB and heat it should be lubricated enough and heated up enough to come off. If you hit the bolt for a few seconds then stop, and hit it again, the metal is gonna heat then cool causing the metal to expand and contract and its just gonna be a bitch to get off.
If the OP is replacing the transmission hopefully he will do axles as well and new axles come with new axle nuts, so don't worry about destroying the nut.
Quick Reply: frozen axle nut
