Front lower ball joint boot circlip part? Diagram included
Old 02-10-2014, 05:51 PM
JohnnyEF's Avatar
Default Front lower ball joint boot circlip part? Diagram included
Looking to buy the front lower ball joint boot and circlip for my 93 civic HB cx. I am not sure the difference between the two ref#20 and ref#10? My front lower ball joint boot ripped yesterday while trying to separate the lower control arm from the knuckle. Any help would be appreciated. Thanks
Ref #: 020 Honda Part: circlip (outer) (40mm)
Part Number: 90653-SB0-000
Standard Qty.: 002
Mfg. Origin: 'CAN'
Ref #: 010 Honda Part: circlip, control arm
Part Number: 52338-SL0-003
Standard Qty.: 004
Mfg. Origin: 'CAN'
Old 02-10-2014, 06:30 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Front lower ball joint boot circlip part? Diagram included
I could be wrong here, but I believe 10 holds the boot, while 20 holds the balljoint into the upper A arm.
Old 02-10-2014, 06:52 PM
Wdpfreak145's Avatar
Why not just buy a new ball joint? Worth replacing if you haven't done so already.
Having said that, here's the "secret" method for freeing ball joints/tie rod ends/etc: Take your BFH and wack on whatever it mounts to a good 5 or 6 times. Really wail on it. You won't hurt anything as long as you're striking where you're supposed to. Eventually, tap on the bolt from the bottom side and if it's free it will come up. If not, keep smacking the side. This will free it and it will prevent you from ******* the threads all to hell and having to use a ball joint separator which almost always destroys the boot.
Old 02-10-2014, 08:21 PM
Hysterically Calm
TomCat39's Avatar
There is another trick to pop the lower ball joints, we did this when doing my tranny swap. No beating necessary. Just a floor jack and a solid extension. Maybey a slight tap on the extension once pinched. No Damage to anything.
Old 02-11-2014, 02:54 PM
JohnnyEF's Avatar
Easier fix to just replace the boot. The ball joint requires some tools I don't have and the ball joint seems fine. Anyone have input on the circlip?
Old 02-11-2014, 04:50 PM
Seagull Management
94EG8's Avatar
I always just carefully removed the old clip and reused it, looking at the diagram though it should be reference 20.
Btw you don't need any special tools to replace the ball joint if you remove the knuckle from the car. A hammer and a large drift punch is all you need. But if it's a good OEM Honda ball joint there's nothing wrong with replacing just the boot, I've certainly done it before as well, for the same reason you are.
Old 02-11-2014, 10:57 PM
SaberLily's Avatar
#10 is the metal ring clip that holds the boot to the ball joint.
Old 02-12-2014, 04:27 PM
belairbrian's Avatar
#10 is for the UPPER ball joint. #20 is for the LOWER ball joint
Old 02-12-2014, 04:36 PM
schollianmj's Avatar
well if you look at the posted diagram, number 10 is on both the upper and the lower.
Old 02-12-2014, 04:54 PM
Seagull Management
94EG8's Avatar
I think I was wrong in my previous post, go with 10, both call for 10, but only the lower calls for 20.
Old 02-14-2014, 08:48 AM
JohnnyEF's Avatar
Thank you for your input fellas. I will purchase #10.
Hala
08-08-2009 10:31 PM
halocore
03-07-2009 04:34 PM
Hemix
01-20-2008 07:38 AM
s-tech
08-06-2005 10:30 AM
Quick Reply: Front lower ball joint boot circlip part? Diagram included
