EDM EK4 - Immobilizer problems
Old 02-07-2010, 12:12 PM
bobobob's Avatar
Default EDM EK4 - Immobilizer problems
I'm in the process of swapping a b16a2 and i think i'm going to get some troubles with the immobilizer.
The engine is a b16a2 complete with ECU obd2b out of a 99 EK4 and it's going into a 96 EK3 obd2a car.
(The old engine from my car is swapped into a ej9 including the transponder ring and immobilizer. This one runs perfect right after the first start)
Now i took the transponder ring and immobilizer from the EK4 and here the problem is. It seems that when the facelift came they also started using different immobilizers, so i can't just plug the 99 immo into the 96 harness.
Is there anyone here who knows how to workaround this or has the wire schemes of both so i can just replug the wires.
Thanks!
bobobob is offline
Old 02-07-2010, 12:57 PM
Seagull Management
94EG8's Avatar
Default re: EDM EK4 - Immobilizer problems
I'm sorry to say I wont be much help with this one. We didn't get immobilizers on any '96 - '00 Civic here in north america. We did get them on '00 - '01 Integras (which you can remove and replace with a dummy chip to prevent a CEL) I would suggest you try that, or try a USDM or JDM ECU that lacks the immobilizer.
94EG8 is offline
Old 02-07-2010, 04:04 PM
xero_xero's Avatar
go obd1 with a jumper harness... quite a bit better for tuning and upgrades.
as for the ecu problem, you will need to swap in an immobilizer ring and a coded key/ecu pair.
you can bypass this with a hondata s300 chipped ecu because you can turn on and off the immobilizer.
xero_xero is offline
Old 02-12-2010, 12:54 AM
bobobob's Avatar
Xero, the idea was to swap over the ecu, immobilizer, transponder, and key from the donor car. That way it's going to work for sure!!
But now the 2 cars have different immo's its a smal bump.
Is there anyone who knows what the immobilizer chip in the ecu looks like? And where to get the dummy and perhaps a diy to replace this?
Thanks!
Don't want to go with obd1 yet, first have to get this up and running
bobobob is offline
Old 02-12-2010, 07:23 AM
xero_xero's Avatar
here is the guy to talk to, he said that he could bypass the chip for cheap though he would not discuss the exact details on the boards.
https://honda-tech.com/forums/audio-security-video-27/transponder-immobilizer-bypass-1471478/
wrx-killer-Sti-eater is his name on honda tech.
he can bypass your oem ecu transponder circit.
Old 02-12-2010, 11:14 AM
bobobob's Avatar
ok thanks, i read the thread and it seems like i have to send him the ecu.
Since i'm in europe, it's going to take a while.
I do work at a Honda dealership so one of the mechanics is going to see if he can adjust the immobilizer, see how that works out....
If that's not going to work i'll get in touch with wrx-killer!
bobobob is offline
Old 02-12-2010, 11:35 AM
NOOdS's Avatar
i used a obd2a ecu with jumper harness.
NOOdS is offline
Old 02-12-2010, 12:13 PM
xero_xero's Avatar
i personally use the oem Honda HDS diagnostic tool which allows for programming and diagnostic tools. its hard to get a old of but may be more reliable in the future. your honda techs will have it on hand to program. it is an OEM honda tool
Old 02-12-2010, 12:47 PM
bobobob's Avatar
Yeah, but the USDM ecu's / cars dont have the immobilizers
The techs have the HDS tool. He is the one who suggested to me he MIGHT be able to adjust the immobilizer in such way that i will be able to just use my "old" keys with the new immobilizer.
Do you know if it is possible?
I'm still waiting for my jumper harness to get it all connected. (it has been shipped out about 2 weeks ago from cali, i just hope the mail doesn't go through NY, cause then i probalby have to wait quite a while )
bobobob is offline
Old 02-12-2010, 12:49 PM
HCivExoo's Avatar
learn something new everyday! thanks XERO
HCivExoo is offline
Old 02-12-2010, 12:55 PM
NOOdS's Avatar
mine did, 2000 gsr. i couldnt use my original obd2b ecu that came with the motor.
my mechanic buddy said that late 99-01 gsrs have mobilizers.
NOOdS is offline
Old 02-12-2010, 12:59 PM
bobobob's Avatar
ok, as far is i've read the ek's in the state didn't and the 99-00 integra's did have them.
Even if i use a obd2a ecu they have the immo in it, so wont be able to do that either.
bobobob is offline
Old 02-12-2010, 03:51 PM
xero_xero's Avatar
USDM cars that had immobilizers were Prelude 97-01, Civic 2001+, Integra GSR 98+, Integra/RSX 2002+. NSX 2000+. CRV 2002+, S2000 99+, Odyssey ?, Insigt ?, Accord 98+, Fit ?,
immobilizers are pairs of programmed Keys/ECUs. The immobilizer Contains an RFID chip that communicates a lengthy code that the computer verifies. you can program any ecu to accept any coded key with the correct length of code. the immobilizer ring acts as a power source/ receiver (no rfid has an internal power source, it receives power externally just like credit cards you dont have to swipe) and receives the power, transmits the code which in turn allows the ecu to start the car.
the immobilizer just has to be programmed by the windows based unit, not the old green screen unit, they dont seem to work as well and have damaged some ECUs. Hondata has a write up on the kPro chipped unit, but it works the same with all ECUs.
Old 02-12-2010, 10:01 PM
bobobob's Avatar
Xero, thank-you for your very complete answer. It seems that i have to go spend some time with the hds tool and a mechanic!
I hope it all is going to work out a lot easier than i thought it would be!
bobobob is offline
Old 02-13-2010, 01:36 PM
Seagull Management
94EG8's Avatar
No '98 Integras had an immobilizer, they were only featured on all '00 - '01 models.
94EG8 is offline
Old 02-20-2010, 06:55 PM
xero_xero's Avatar
my bad 00-01 integras. rep for noticing.
update on immo problem fix?
Old 02-23-2010, 06:53 PM
xero_xero's Avatar
did we ever get an update? have a fix if your still having immobilizer problems.
Old 02-23-2010, 08:13 PM
bobobob's Avatar
Yeah, i might have the solution for the problem. Right now i'm in the states for a week.
As soon as i get back next week i'm going to try the solution i have now, and see if it works.
If so, ill update again!
bobobob is offline
Old 02-23-2010, 08:40 PM
xero_xero's Avatar
if anything, i can show you how to remove the immobilizer board with ease.
Old 05-05-2010, 07:14 AM
xero_xero's Avatar
updates? know its been a few months...
Old 04-09-2012, 10:20 PM
jdmrexy90's Avatar
i know its an old thread but i was working on my 00 Ls steering column, i accidently cracked the immobilizer unit in half ans the little metal box with a weird pin had the wires cut. now i have a crank no start. ive tried a chipped p28 but it didnt start. I later realized at work i still had the immo plugged to the harness while using the obd1 ecu, maybe i have unplugged it? IDK but someone please help. Honest to God, this is my DD and i need it back. I missed out on V2lab because of this
jdmrexy90 is offline
Old 01-05-2015, 05:54 AM
ricjoh67's Avatar
Zero_Zero... I realize this is a REALLY old thread.. but are you still interested in showing how to remove the immobilizer board?
This is so friggin irritating!
I talked to my local Honda dealership today and their only solution was to buy a complete new key/code unit (04809-S04-G02) (since I don't have a red key..) and then bring the car in to have these parts installed... before programming additional keys.
Sounds ridiculous to me for a car worth next to nothing.
I just want to make sure I can still start the car when my son loses the last chip..
ricjoh67 is offline
Old 01-05-2015, 06:32 AM
Former User's Avatar
Default Re: Immobilizer problems
What car and ECU?
Former User is offline
Old 01-05-2015, 09:27 AM
Fish Twig
tony_2018's Avatar
Default Re: EDM EK4 - Immobilizer problems
Best get the keyring for your year, and find on obd2b to obd2a conversion harness within your region of the world. That way they have all the specific wires you need. AFter that you'll need to reprogram it by using the red key. hopefully that works.
tony_2018 is offline
Old 01-07-2015, 05:47 PM
AlwayzN2Sumthin's Avatar
Do you want to remove the immobilizer altogether? or replace it?
You could just pick up an ecu and set of keys from a scrap yard and save yourself some work.
On the p28 ECU the immobilizer is labeled "IMMO-A0".
AlwayzN2Sumthin is offline
Quick Reply: EDM EK4 - Immobilizer problems
