draining and flushing coolant out of block!?
Old 10-28-2006, 11:52 PM
93(Civic)EG6's Avatar
Default draining and flushing coolant out of block!?
Anyone know where the drain plugs are for the coolant located on a b16?? It is somewhere near the oil filter?
Old 10-29-2006, 01:13 AM
anothersickhatch's Avatar
Default Re: draining and flushing coolant out of block!? (93(Civic)EG6)
the drain plug to release coolant is on the front of the block underneath the motor stamp. it should be right below and to the right of the "b16a" stamp.
i think its a 19mm bolt with a washer on it.
Old 10-29-2006, 01:44 AM
HT White Ops
Eran's Avatar
Default Re: draining and flushing coolant out of block!? (anothersickhatch)
My coolant drains are behind my exhaust manifold on my ls
Old 10-29-2006, 02:13 AM
nello a.'s Avatar
not necessary. the radiator draincock is the lowest point in the system. drain -fill with distilled water-run heat-drain-fill with honda premix(add some redline if you are inclined) or 50% prestone(or something brand name) and 50% distilled water.
Old 10-29-2006, 07:40 AM
Default Re: (nello a.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nello a. &raquo;</TD></TR><TR><TD CLASS="quote">not necessary. the radiator draincock is the lowest point in the system. drain -fill with distilled water-run heat-drain-fill with honda premix(add some redline if you are inclined) or 50% prestone(or something brand name) and 50% distilled water.</TD></TR></TABLE>
Yes it is cause i am changing my type of coolant !!! Need to completely flush it!!!
Thanks every1 for the help!
whiteGSR
07-26-2022 03:06 PM
Rvu
01-29-2010 08:15 AM
mikestypeRR
11-17-2005 01:11 PM
dman81
03-07-2005 10:19 AM
Quick Reply: draining and flushing coolant out of block!?
