doing mini me right now help out. the crankpulley wont come loose
Old 12-22-2003, 10:20 AM
Ignitecivic's Avatar
Default doing mini me right now help out. the crankpulley wont come loose
i doing my mini me now and im use the power tool wrench and the damn crank pulley bolt wont come loose. is there any other way i can get these sucker out if my impact wrench dont work. help out. thanks
Old 12-22-2003, 10:23 AM
Moderator
chad's Avatar
Default Re: doing mini me right now help out. the crankpulley wont come loose (Ignitecivic)
buy the right tool...or make your own....moroso makes a tool for that!
Old 12-22-2003, 10:25 AM
Global Moderator
Jimmy's Avatar
Default Re: doing mini me right now help out. the crankpulley wont come loose (chad)
Pm Bauleycivic for this one
Old 12-22-2003, 10:32 AM
Default Re: doing mini me right now help out. the crankpulley wont come loose (USDMDC2)
make my own tool. wat u mean by that. damn crank pulley is pissing me off. electric impact wrench too weak or something.
Old 12-22-2003, 10:35 AM
Moderator
chad's Avatar
get a pipe....drill one hole in it....at the tip....put 14mm bolt through, then measure distance to offset hole....then drill another hole....and put 14mm bolt through....you have your own breaker bar!
Old 12-22-2003, 11:33 AM
Dancing is Forbidden's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">get a pipe....drill one hole in it....at the tip....put 14mm bolt through, then measure distance to offset hole....then drill another hole....and put 14mm bolt through....you have your own breaker bar!
</TD></TR></TABLE>yup slagger and I had to do this on his mini-me.
Old 12-22-2003, 12:05 PM
jhiz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic &raquo;</TD></TR><TR><TD CLASS="quote">i doing my mini me now and im use the power tool wrench and the damn crank pulley bolt wont come loose. is there any other way i can get these sucker out if my impact wrench dont work. help out. thanks</TD></TR></TABLE>
crank the PSI to the max and get a higher torque air gun(350 ft/lbs or more). that will take that bolt out in no time....no other special tools needed! just a better air gun. trust me
Old 12-22-2003, 12:07 PM
Tomek's Avatar
Default Re: doing mini me right now help out. the crankpulley wont come loose (jhiz)
I just went at mine with an air gun for a little bit, just when I was about to give up the sucker broke loose.
Old 12-22-2003, 12:50 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: doing mini me right now help out. the crankpulley wont come loose (AztecEJ)
pull off your starter
wedge a close ended wrench inbetween the flywheel teeth and the tranny housing
take big breaker bar and remove bolt
done
Old 12-22-2003, 01:44 PM
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhiz &raquo;</TD></TR><TR><TD CLASS="quote">
crank the PSI to the max and get a higher torque air gun(350 ft/lbs or more). that will take that bolt out in no time....no other special tools needed! just a better air gun. trust me</TD></TR></TABLE>
not all the time....
Old 12-22-2003, 01:50 PM
EPIC TUNING
E-Rok's Avatar
put the car in gear and have someone press on the brakes and use an impact gun. thats how i got mine off
Old 12-22-2003, 01:55 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Pm Bauleycivic for this one </TD></TR></TABLE>
Definately, that kid knows his **** with the mini me.
Old 12-22-2003, 02:07 PM
93civicEX's Avatar
don't use any kind of extension, It takes torque away from the impact wrech, Just use a deep socket. Also Do you have your impact wrech turned to the most powerful setting?
Old 12-22-2003, 02:59 PM
Civiclx's Avatar
Default Re: doing mini me right now help out. the crankpulley wont come loose (Kikomon)
Four steps:
(1) use a deep socket 17 mm i believe
(2) have someone slam on the brakes in 5th gear
(3) have someone else hold the flywheel still with a punch or pick of some sort, be careful to make sure its not on the thinnest part of the bell housing or it WILL crack
(4) get your strongest person to turn that torque wrench
I did it this way and am finally done with the minime. good luck!
Old 12-22-2003, 04:52 PM
xcchicx's Avatar
Default Re: doing mini me right now help out. the crankpulley wont come loose (Civiclx)
the method of having someone stand on the brakes with it in gear worked for me. good luck on your swap, mine is still in progress. the motor rotates but wont start all the way.
Old 12-22-2003, 05:02 PM
Civiclx's Avatar
Default Re: doing mini me right now help out. the crankpulley wont come loose (xcchicx)
good luck on the minime!
Old 12-22-2003, 05:24 PM
Risky Business
BauleyCivic's Avatar
I cant say anything that hasnt been said here...I got mine off after about 10 mins with an impact gun, 90psi, and WD-40. If that doesnt work...the answer is more torque meaning more PSI. Shops have like 150 psi on tap...so if nothing else works that's where you will end up
Old 12-22-2003, 05:37 PM
Default Re: doing mini me right now help out. the crankpulley wont come loose (BauleyCivic)
heres another one noone said: Take a piece of rope and take out the sparkplug in the number 1 cylinder. Make sure it is coming up on TDC (so no valves are open) and shove the rope in. crank the engine just a little bit until the piston can no longer move. Then impact the Bolt off.
Old 12-22-2003, 09:33 PM
superls92's Avatar
Default Re: (93civicEX)
put the car in fifth gear and have someone hold the brakes when you turn it.
also use a breaker bar with a cheater bat that's what I did.
Old 12-22-2003, 10:06 PM
Default Re: (superls92)
thanks for all the tips. dang i did everything until i got the crank bolt. took me long *** time and still dotn come out. i tried the 5th gear, stomp on brake and even use a spare tires and lower it, still dotn break loose. so i gave up and put every shiet back to stock and try another day with the air gun.
Old 12-22-2003, 11:40 PM
Import Alliance
Don Napier's Avatar
Default Re: (Ignitecivic)
Air is where it is at!
Old 12-23-2003, 04:03 AM
93CivicSI's Avatar
the first time I changed my timing belt (long time ago) I had to use a 600+ ft pound air wrench to break that bolt loose.....
prelude1897
07-11-2006 03:11 PM
puffsef
10-19-2005 09:50 AM
Ferrell
05-22-2005 10:41 AM
TRH
09-30-2003 04:50 PM
ebelp
05-13-2003 03:49 PM
Quick Reply: doing mini me right now help out. the crankpulley wont come loose
