DIY : WINDOW TRACK PROBLEM
Old 04-07-2008, 12:11 AM
  #26
Skuba_Steve's Avatar
good ****
Skuba_Steve is offline
Old 04-07-2008, 01:21 AM
  #27
RS2 FAB's Avatar
Default Re: (gtlaw1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtlaw1 &raquo;</TD></TR><TR><TD CLASS="quote">hondas are supposed to be good cars, but honda really dropped the ball on this **** my 96 dx with manual windows has all kinds of problems with this crap.... expletive honda they suck how could they possibly expletive up something that had been perfected many decades earlier [freak]ing idiots</TD></TR></TABLE>
haha ever own a VW gti? the newer 1.8t kind?
try going through $200-250 window motors every few years
RS2 FAB is offline
Old 04-07-2008, 05:35 AM
  #28
96 Honda Civic EX Owner's Avatar
Default Re: DIY : WINDOW TRACK PROBLEM (p0tential)
Have had to do this 3-4 times with the power windows on my 96 Civic, but no one has ever thought to lube up the track as a solution... I just try not to use my windows much, and I will NEVER put them down all the way... lol.
That said, can you apply the silicone spray without disassembling the door? If so, any suggestions on the best way to do this? Also, would WD-40 be okay to use, or is there something better?
One last thing, I read in another thread on this issue that you should be careful not to get the silicone spray on plastic or rubber as it would eventually eat away at it... someone even went as far as recommending using graphite rather than silicone to lube the track.
Thoughts?
96 Honda Civic EX Owner is offline
Old 04-07-2008, 07:07 AM
  #29
Apotheosis's Avatar
im glad this got bumped this morning because this just happened to me about 2 hours ago on my way to school. i put the window down to pay a toll, and tried to put it back up and it came off the track. now its sitting downtown in a deck with a window open until i can do this
Apotheosis is offline
Old 04-07-2008, 10:27 AM
  #30
Default Re: DIY : WINDOW TRACK PROBLEM (96 Honda Civic EX Owner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 Honda Civic EX Owner &raquo;</TD></TR><TR><TD CLASS="quote">Have had to do this 3-4 times with the power windows on my 96 Civic, but no one has ever thought to lube up the track as a solution... I just try not to use my windows much, and I will NEVER put them down all the way... lol.
Thoughts?
Hi, still looking for information on this one.
Old 04-08-2008, 08:28 AM
  #31
Thoughts?
Can anyone help? I'd love to enjoy the spring weather in my car this year.
Old 04-08-2008, 08:54 AM
  #32
unsungfate's Avatar
beautiful! i was looking for just the DIY mine cam off its track at a carls jr drive thru... was so angry!
unsungfate is offline
Old 04-08-2008, 11:36 AM
  #33
Thoughts?
bump
Old 04-08-2008, 12:21 PM
  #34
SuperSonikBluEK's Avatar
nice write up! mine keep continuously falling off the track...because its just a temporary fix...i eventually had to go to the honda dealership and get a new track installed
SuperSonikBluEK is offline
Old 04-08-2008, 12:32 PM
  #35
born2bmx's Avatar
good writeup has'nt happened to me yet.
born2bmx is offline
Old 04-08-2008, 01:30 PM
  #36
Default Re: DIY : WINDOW TRACK PROBLEM (SuperSonikBluEK)
Can anyone tell me if lubricating the window track can be done without taking my door apart, and if so, the best way to do it?
Also, is WD-40 an acceptible silicone spray to use, or is there something different?
And finally, does silicone harm rubber plastic over time, and should graphite be used instead?
Thanks!
Old 04-08-2008, 01:43 PM
  #37
b18c1sircivic's Avatar
same thing happened to me with my drivers door...the bad thing was that it was raining that day
b18c1sircivic is offline
Old 04-08-2008, 06:20 PM
  #38
93preludeh22's Avatar
what is the preferred method for getting the plastic crap to stick back on the door?
93preludeh22 is offline
Old 04-08-2008, 06:58 PM
  #39
R81_EJ7's Avatar
Default Re: (93preludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">what is the preferred method for getting the plastic crap to stick back on the door?
any type of like thick silcone.
and i had to learn this the hardway, trial and error. lol
nice write up.
R81_EJ7 is offline
Old 04-09-2008, 09:45 PM
  #40
p0tential's Avatar
you can lube it with out taking the door off....put the window all the way down and use the straw that comes with the silicone spray can. then put it inside the tracks and spray away....if you use too much you will see it drip out the drainage spots on the the bottom of the door. it doesn't really matter since is a lubricant so it wont hurt anything.
i'm not sure on the silicone being a deterant on the rubber. i would say no, it should be fine, since everyone on this forum suggests using it.
i would not use wd-40. it is an oil based lubricant and will not penitrait well into the rubber on the tracks. it will also leave an awful residue on your window that will be a pain to remove.
hope this helps, sorry it took 4 bumps for someone to reply.
i'm gald people are still using this, i wrote this last summer, thanks for the replys.
p0tential is offline
Old 04-10-2008, 06:06 AM
  #41
EJ8freek's Avatar
Thanx for the DIY. This is a common problem in civic coupes. I had the same problem but I replaced the window regulator.
EJ8freek is offline
Old 04-11-2008, 01:27 PM
  #42
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0tential &raquo;</TD></TR><TR><TD CLASS="quote">you can lube it with out taking the door off....put the window all the way down and use the straw that comes with the silicone spray can. then put it inside the tracks and spray away....if you use too much you will see it drip out the drainage spots on the the bottom of the door. it doesn't really matter since is a lubricant so it wont hurt anything.
i'm gald people are still using this, i wrote this last summer, thanks for the replys. </TD></TR></TABLE>
Thank you!!! I'll give it a try this weekend.
Old 04-11-2008, 01:39 PM
  #43
eg8000rpm's Avatar
good write-up I will try this tomorrow when the weather gets warmer.
eg8000rpm is offline
Old 05-14-2008, 02:47 AM
  #44
allmotorteg_96's Avatar
Default Re: DIY : WINDOW TRACK PROBLEM (eg8000rpm)
thanks for the write-up. this is my project for the day
allmotorteg_96 is offline
Old 05-17-2008, 02:05 AM
  #45
Default Re: DIY : WINDOW TRACK PROBLEM (allmotorteg_96)
it took me about 10-15 min. and it works great.
Old 10-05-2008, 09:08 PM
  #46
badbu68's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by p0tential &raquo;</TD></TR><TR><TD CLASS="quote">i'm not sure on the silicone being a deterant on the rubber. i would say no, it should be fine, since everyone on this forum suggests using it. </TD></TR></TABLE>
Silicone won't hurt rubber, infact it's a good thing to spray some on your weatherstripping to keep it soft.
badbu68 is offline
Old 10-05-2008, 09:29 PM
  #47
GuCBlackEk's Avatar
nice write up. my windows all messed up too but its a manual.
GuCBlackEk is offline
Old 10-05-2008, 10:56 PM
  #48
mattyv's Avatar
nice writeup
mattyv is offline
Old 10-06-2008, 06:06 AM
  #49
tercel95's Avatar
Happens to me regularly, I think its worse though because someone pried the window off the track to break into the car. Oh and to the guy that asked I just took all of that plastic crap off.
tercel95 is offline
Old 10-06-2008, 07:36 AM
  #50
ghs_3MTA3's Avatar
silicone sprays the way to go! couldnt get window all way up without having to help it along. then added the spray and works like mint
ghs_3MTA3 is offline
Quick Reply: DIY : WINDOW TRACK PROBLEM
