Disabling fuel system?
Old 09-24-2005, 03:11 PM
O16581724 5 2 5's Avatar
Default Disabling fuel system?
I believe i have a blown headgasket, i'm pressurizing my system currently and will test it by cranking the engine with a paper towel laid over the spark plug holes, any water will shoot on the paper towel, but if it's pouring fuel in, i won't be able to tell. My idea is removing the ECU fuse as the best method, correct?
Old 09-24-2005, 05:00 PM
RedEj8's Avatar
Default Re: Disabling fuel system? (O16581724 5 2 5)
Yea remove the fuel pump fuse
Old 09-24-2005, 06:21 PM
nota-eg's Avatar
Default Re: Disabling fuel system? (reddohcvtec)
Remove the fuel pump fuse, ecu fuse, ecu, or disconnect your injector wires.
Old 09-24-2005, 07:55 PM
mike93eh
Guest
Posts: n/a
juist remove the ecu fuse
Old 09-24-2005, 09:34 PM
m00nr0ck Si's Avatar
Default Re: (mike93eh)
fuse # 31 under hood fuse block.
Old 09-25-2005, 12:46 AM
ECU fuse does it, i hadn't gotten a reply as soon as i thought i would so i tried it anyway because i was 99% sure that'd do it. Head gasket seems good from that test, car pulls hard as hell for 8.5 compression, i beat a bolt-on H22A Civic with ease at 10psi (D16Z6), so i can't explain all the smoke (it's a very large amount) out my exhaust and coolant loss, might just be a coincidence and the two aren't related.
Old 09-25-2005, 06:17 AM
Chiovnidca's Avatar
Default Re: Disabling fuel system? (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote"> or disconnect your injector wires.</TD></TR></TABLE>
Don't do that, you'll risk damaging your ignition coil.
Old 09-25-2005, 06:19 AM
nota-eg's Avatar
Default Re: Disabling fuel system? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Don't do that, you'll risk damaging your ignition coil.</TD></TR></TABLE>
Didn't know that. Thanks.
Old 09-25-2005, 09:03 AM
siregcivic's Avatar
just unplug the dizzy while ur at it
Old 09-25-2005, 09:16 AM
nota-eg's Avatar
Default Re: Disabling fuel system? (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">just unplug the dizzy while ur at it</TD></TR></TABLE>
Doing all that he's better off just pulling the ECU fuse.
Or did I miss out on some internet sarcasm?
Ananth
Honda Civic (2001 - 2005)
04-13-2024 11:20 PM
BBuncky2
09-02-2008 05:13 AM
BlueShadow
25
07-08-2005 09:43 AM
tmekjian
05-08-2003 08:17 AM
Quick Reply: Disabling fuel system?
